Fri, Nov 15, 10:02 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: making a smart prop with poser7
hhfspinball ( ) posted Sat, 14 April 2012 at 4:01 PM · edited Fri, 15 November 2024 at 9:56 AM
I am having trouble making a smart prop with poser7. I can load the prop and set the parent but I can't get the window that asks if I wish to save the prop as a smart prop live in older versions of poser. I can save the prop as a prop but as a smart prop. It loads in the right spot but won't move unless I go back to the heirarchy room and reset the parent. any ideas on how I can save this prop to a smart prop?
Bill
jancory ( ) posted Sat, 14 April 2012 at 8:38 PM
The smartprop dialog won't come up if you choose Select Subsets in the Save window. so don't do that! Just parent your prop & save straight to library. otherwise, hand-editing the saved pp2 is your only other choice. hope this helps.
lost in the wilderness
Poser 13, Poser11,  Win7Pro 64, now with 24GB ram
ooh! i guess i can add my new render(only) machine!  Win11, I7, RTX 3060 12GB
 My Freebies
hhfspinball ( ) posted Sun, 15 April 2012 at 9:24 AM
that was it. thanks for the help. was able to do this with older versions of poser but this one kind of threw me.
jancory ( ) posted Sun, 15 April 2012 at 9:26 AM
poser's good at throwing curves. glad to help.
 My Freebies
