Sat, Jan 25, 11:57 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: python script Poser to After Effect
andygraph ( ) posted Sat, 07 April 2012 at 3:30 AM · edited Sat, 25 January 2025 at 11:38 PM
Please i need a script for export poser motion camera (+ origin props)  to after effect.
Is it possible ? Any can work on it ?
thx
Andy
timarender ( ) posted Sat, 07 April 2012 at 4:25 PM
What properties of the Camera are you wanting to convert?
What properties of the "+origin prop" (whatever they are!) do you want to convert?
In generating the suitable JSX file for After Effects, which properties in Poser would you want mapped to settings in After Effects.
It is possible, within the restrictions of AE's notion of 3d; but I doubt anyone has a handy script close nearby.
May I ask. Why do you want to perform this export/import?
andygraph ( ) posted Sun, 08 April 2012 at 1:49 PM
hmm .. all camera motions .. i dont know .. rotation and position ... camera and pivot reference?
Origin prop in scene (to 3d null object in After effect)
i know about a script python blender to after effect ..
Just i like the make the animation and render in poser and make the compositing in AE but with the same camera of poser so i can add 3d layer ;-)
markschum ( ) posted Sat, 14 April 2012 at 5:58 PM
file_480453.txt
I made a script for Sixus1 back in 2009. O dont remember what it was used for but here is a vrsiom that may give you some ideas.
andygraph ( ) posted Mon, 16 April 2012 at 5:33 AM · edited Mon, 16 April 2012 at 5:46 AM
Hmm this script import the data from VoodooCam .. i believe ..
but i need a script for export from poser all camera motion and props/actor position to After effect.
questa è una versione blender to AE
https://svn.blender.org/svnroot/bf-extensions/trunk/py/scripts/addons/io_export_after_effects.py
maybe is usefull for create a script poser to AE ?
thx
