Sat, Feb 1, 3:18 AM CST
Forum Moderators: Staff
Subject: Carousel texturing????????
designer2001 ( ) posted Fri, 31 August 2001 at 1:56 AM · edited Thu, 14 November 2024 at 6:18 PM
I made a UV Map and texture of the Carousel (by copying the original object and then UVMapper-ing it) and loaded a naked carousel into poser 4 workspace. I apply the texture and it doesn't render in workspace so I go to render in a large window and it renders with the map I made AND the one it came with. How do I extract and get rid of the original texture (which must be imbedded in the pz2 file?) ? MJ
ScottA ( ) posted Fri, 31 August 2001 at 10:26 AM
Why don't you delete the existing .pz2 file (*make sure you save a copy somewhere in case you make a mistake)? Then Import the new .obj file you just ran through UVmapper, apply the texture, then save it to the library. Poser will then automatically create a new .pz2 file for you. ScottA
designer2001 ( ) posted Fri, 31 August 2001 at 6:01 PM
Thanks! I'll try that. MJ
