We decided that offering a way for people to delete files was pretty dangerous. The number of users complaining and accusing Poser of doing things that were actually done by themselves is rather high. So, Poser is incapable of deleting, therefore cannot be accused of doing it incorrectly.
As to grouping files, what do you mean? You have near total freedom to organize how you like. You can move things around in Poser with drag and drop, or use your file manager.
@BB ..You have near total freedom to organize how you like.
As usual I might be doing things the wrong way around, but
This makes building one "closed set" of dress, other clothing items, shoes, jewelry, purse, and a shipload of sets of materials still some nightmare. To me that is.
So I stick to P3dO for the time being, despite all efforts of BB into this Library (and the serious improvements he really made). But I like to be educated...
visit www.aRtBeeWeb.nl (works) or Missing Manuals (tutorials & reviews) - both need an update though
@GeneralNutt (and BB): yep, tested again. Don't know what went wrong last time, but now:
But...
Same behavior in PPro2012 as in PPro2010.
Right. With P8 anyway, the Library system still has certain limitations that appear to have lingered from older versions. You are also limited to saving poses only to the Pose library, materials to the Material library, etc. So if you have an outfit that's in the Characters library and you've placed all if its materials in a subdirectory under the outfit called Mats for example, you can't save a material in the Mats subdirectory; you have to save it somewhere in the Materials library. After that you can move it anywhere you want with Explorer, but you have to save it to wherever Poser expects it to be saved.
OS: Windows 10 64-bit, Poser: 10
What path is the library showing? What path are you looking in? (See chapter 7 for library display options)
Quote - We decided that offering a way for people to delete files was pretty dangerous. The number of users complaining and accusing Poser of doing things that were actually done by themselves is rather high. So, Poser is incapable of deleting, therefore cannot be accused of doing it incorrectly....
However, it will happily overwrite compressed files without prompting if file compression is disabled, and vice versa. I filed a bug report and was told that mixing compressed and uncompressed files was not supported, and it was thus not a bug... :rolleyes:
"Oh - the manual says that? I have never read the manual - this must be why."Quote - I didn't write that part. grin
I figured that you didn't.
They probably would need to rewrite the gzip library to fix it...
"Oh - the manual says that? I have never read the manual - this must be why."What paths? I do not have time to ask all the questions. Since you did not give me data, I will tell you to look up UAC and virtual store.
OK it is as I suspected. UAC is active and you attempted to install content into program files.
The Poser installer very strongly suggested you not put your main runtime into Program Files. Yet you did. Now you know why it was strongly suggested not to do that.
Windows will not let 3rd party installers shove files into Program Files unless you jump through some hoops.
You have two choices. Start over and you will never have to think about UAC and the Virtual Store.
Or - start learning what you did, what Microsoft did, what Daz did, and how those three things are in violent disagreement.
The best solution is to install your main content in your documents folder, not your program files folder.
Further, 3rd party content really should not be jammed into your main runtime at all. You will eventually be sad after you have upgraded Poser several times, and you are still carrying around your current main runtime, even though it will have been superceded by newer better ones in the future.
You'll be forced to keep it around because you jammed a bunch of stuff you did not get from SM into the place where you keep (and eventually throw away) what SM gave you.
Another to-do for SM, I guess.
Copying paths from the detail panel works for me all the time - odd.
Can't delete mistakes. Install in the wrong place or empty and can't delete.
Can't even get files grouped so that they make some sense. 4 days and my hair is
turning gray. I think I need step by step help.
