Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
Quote - If the error is occurring in Poser Debut, then it may not work in Poser 8 version and up including the pro series. Poser Debut is an offshoot of P8.
I would have thought that too, but the vendor said he got it to work in Poser 8 but did not have PP2012 or P9 to try it in. As I mentioned I know it won't work in PP2012 and Debut. I don't really know what could have changed between the versions to cause this.
So:
Poser 7 : works
Poser 8: works
Debut: Error
PP2012: Error
Poser 9: unknown
Thanks
Quote - if you are running a 32 bit Poser what memory does the system (windows task Manager) show once you load the product ?
Yes it's the 32 bit version. I have 2 Gb of RAM and I'm using it and some virtual memory on the HD, if I'm reading it correctly. I only have V4 loaded. Nothing else, and no morphs on her either. Although that's high, I've been to that point before with PP2012 and the large file size of my other models.
I wrote DAZ but they offered no help. The vendor says he was able to duplicate the error in Poser Debut, so it seems to be some difference between older versions of Poser and any new version released in in the last year or so. Does anyone know of a difference between the versions of Poser that would trigger such errors?
Thanks
