Tue, Jan 7, 12:05 AM CST
Subject: Poser issue
Nosiferret ( ) posted Sat, 26 May 2012 at 5:46 PM · edited Mon, 06 January 2025 at 11:59 PM
I was wondering if anyone has had this situation. I loaded a series of poses back in July of last year. I've used them between then and now. But today I go to use them and they are not in my runtime, anywhere. I locate the poses in my saved files and when I extract the files again, they load as if they were not in Poser but the Readme files were still in Poser back from July.
I have noticed this with clothing items, and props as well. I had 5 folders that had a series of poses in each folder and each folder started with the authors name, all of those poses were loaded in July and all of them missing out of the Runtime but the Readmes show proof that they were loaded at some point.
Is this a sign that my hard drive is getting ready to go belly up? Or just one of Poser flukes? Seems kind of fishy to me, stuff disappearing like that.
basicwiz ( ) posted Sat, 26 May 2012 at 5:50 PM
I've never had this, but I do have one particular item that if unpacked in one runtime works fine. If unpacked in another, it does not show up.
My gut level advice is for you to run a test on your hard drive, and back that sucker up as soon as you can.
If anyone has had your exact problem, I'm sure they will post. Keep checking back.
Demon2330 ( ) posted Sat, 26 May 2012 at 6:53 PM
Never had this problem myself but like basicwiz I have one 2 or two items that did not work if i moved them to another runtime.
Desktop : AMD FX4100 , GT-630 1GB, 4x BD-RE , AOC e2343 23in LED Monitor , 1TB External (120mb/s write speed)(stores my all poser stuff and photo's from camera) and 1TB internal HDD
P2010 , P2012 , P2014 , Reality 3 , Max 2014 , Lightwave 11 , Showcase 2014
Website @ www.steadyrabbitdesign.freezoy.com (New site still under construction) & Dev art : Tim2700
Nosiferret ( ) posted Mon, 28 May 2012 at 4:58 PM
Thanks for posting. It is certainly a strange event. It is probably time for my rebuild on my system and a serious culling of Runtime items. :)
lmckenzie ( ) posted Tue, 29 May 2012 at 1:50 AM
Sounds odd for a HD issue but not impossible. In addition to running an error check, I’d look at the event log for any disk or file system related errors. Generally in the case of a disk problem I’d expect symptoms like noise, Windows throwing errors as it tried to read a bad sector or taking a long time to read a file due to retries. Could be some corruption if the Master File Table I suppose – if so chkdsk will hopefully sort it out. If you reinstalled them and the stay put might be the faeries ÷)
monkeycloud ( ) posted Tue, 29 May 2012 at 5:53 AM
The first thing I'd do here is do an operating system search for one of the file names (e.g. using the Windows Explorer search or Finder, on OS X).
That may reveal what's happened to your missing files.
The first thing I'd suspect is that I had accidentally dragged the files and / or folder inside another folder...
...but that may just be me. LOL ;-)
Demon2330 ( ) posted Tue, 29 May 2012 at 7:52 AM · edited Tue, 29 May 2012 at 7:53 AM
Quote - The first thing I'd do here is do an operating system search for one of the file names (e.g. using the Windows Explorer search or Finder, on OS X).
Good point I used the search method when I placed a runtime folder within a runtime folder , I soon fixed it though after the search.
Nosiferret ( ) posted Thu, 31 May 2012 at 10:11 PM
Good points made, thank you all for the suggestions, I'm working on it now, I have a 500g [not big by todays HDs] 3 year old HD and scan disk will take FORever to go through it...So will have to pick a weekend and let it go. Probably it will take a long time is because I haven't run scan disk on it...so I've been bad I guess... :(
I am always "housecleaning" and putting files into 'proper' file locations for easy use/find in Poser but these files, they can't be found but the readmes were still in place so I know I am not going crazy ;) Thanks again.
