Attached Link: http://rosy-poison.sakura.ne.jp/poser/pgp/pgp-10/pgp-10.html
Therre's a pocket watch and chain in Hisayan's M3 Enbi outfit. I haven't used it myself, but it's poseable and looks reasonably detailed.Thanks EnglishBob
That does look of interest.... I will check it out.
I was looking for something that will scale up probably.
But, even if it's not detailed enough by default for a closer up shot, I might feasibly be able to re-texture it to sort that, if the actual obj is fine enough.
I was probably going to likely slap some BB shaders on the metal parts of whatever I find, in any case... so it would maybe just be a case of making a higher res clock face perhaps.
Cheers ;-)
There's a pocket watch included with the Hatter pack for Gosha
http://www.renderosity.com/mod/bcs/marchhare/76174#
Also there are a couple at sharecg
http://www.sharecg.com/v/16965/View/5/3D-Model/pocketwatch01
http://www.sharecg.com/v/16966/View/5/3D-Model/pocketwatch02
Vive Bene. Spesso
L'Amore. Di Risata Molto.
Live Well. Love Often. Laugh Much.
Thanks Jazzmin :-)
That March Hare one looks good certainly...
I did find the sharecg ones already... the fact they're in obj format isn't necessarily a problem... but I found some issues importing this particular model, as far as I recall...
...also I remember, the usage rights in the readme were in French, so I struggled a bit interpreting... but from what I could make out, it seemed like they might be little restrictive... or at least aren't openly unrestricted?
This may not matter overly, as I'm not making commercial renders or anything like that... but I'm just a bit dubious of using anything where it isn't clear for me upfront regarding how it can be used...
I use Poser 13 on Windows 11 - For Scene set up I use a Geekcom A5 - Ryzen 9 5900HX, with 64 gig ram and 3 TB storage, mini PC with final rendering done on normal sized desktop using an AMD Ryzen Threadipper 1950X CPU, Corsair Hydro H100i CPU cooler, 3XS EVGA GTX 1080i SC with 11g Ram, 4 X 16gig Corsair DDR4 Ram and a Corsair RM 100 PSU . The desktop is in a remote location with rendering done via Queue Manager which gives me a clearer desktop and quieter computer room.
Found one or two actually reasonably priced models on Turbosquid now too (although these are in obj or 3ds format)... I didn't realise there was anything on there around the $5 mark... but there is!
However, Hornet3d's suggestion is still the winner so far, I think ;-)
EDIT: Well... actually... it's maybe between that and the MarchHare set suggested by Jazzmin...
I was digging through some older CDs of poser goodies and found a freebie:
Syspics Digital Imaging Pocket Watch. This is the only link I could find for it: http://www.omskcity.com/~k_av/3dlinks.html
There's one in the freebies at: http://www.renderosity.com/mod/freestuff/details.php?item_id=32519
http://www.renderosity.com/mod/freestuff/details.php?item_id=11611
Hope that helps some
http://nessrepros.co.uk/index.php
There is a barometer at this site that might work from a distance. I didn't hyperlink because Ness has something on his site that prevents access to the site from a hyperlink.
say." - Ghandi
Could anyone recommend / point me towards where I could find a good quality, ready to use, Victorian-esque pocket or fob watch prop, a bit like the one pictured below?
Many thanks ;-)
