Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 19 10:29 pm)
there is NO estimate..
it depends on type of light how many lights what kind of scene how many items are in the scene does it have shadows and how many shadows are there..
what texture size is used on the items... is there any light FX like AO is volumetrics used
Etc etc etc etc etc ...
So lets say it wil take TIME.. just try it out and fill up a scene with things that you need then count and add time from that until you know what you need and time of rendering..
Chris
see http://en.wikipedia.org/wiki/List_of_Pixar_staff
Pixar needs about 4 a 5 people to make a short, I estimate it takes them say 2 months.
the famous Killer Bean 2 (7 min, no fancy lighting or any kind of realism, http://www.youtube.com/watch?v=yMAkMLx-fqs) took Jeff Lew three years on his own computer. Don't know if he had a day job too but I guess so.
My own 3 min animations (http://www.artb.artbeeweb.nl/e107_expose/expose.php?album=10) took about 3 months = 600 - 1000 hours, either to get the scenes and story done (merry go round), either to get the rendering done (mirror in mirror). Cinema4D.
have fun.
visit www.aRtBeeWeb.nl (works) or Missing Manuals (tutorials & reviews) - both need an update though
When rendering animations you should render them as individual frames, then assemble them later. That way you can adjust timings, tweak things, replace frames, etc, without having to re render all of it. It is also way faster if you have multiple machines working together when rendering the frames. I can use hundreds of cores when rendering animations using the Queue manager. I can only use 24 doing an avi.
The time it would take to set up a 1 to 5 min animation will be different with every single one you do. (drastically sometimes)
Some wont take to long at all, others will have you pulling your hair out. It really boils down to the complexity of the scene and how good you are at making it look right.
It also depends on how much of it you can reuse from scenes you have done in the past. Things like a convincing walk cycle can take a while to create. Poser will give you a very basic one, but I find it faster to just make them manually. Once you have that done you can reuse it with different characters fairly easily if the skeletal setup is the same.
If you are serious about animating people, I suggest you learn how they do it for video games first. (interactive animation) The reason I say that is because it will teach you about transistions, timing, etc.
It will also give you a base set of animations to work with. You will probably make about 50 different animation snippets that can be chained together to setup simple animations (video games usually have 150-200 snippets per character but you wont need that many to get started). You can do all of this in Poser, you do not need a video game engine or anything like that.
Some things are easy to explain, other things are not........ <- Store -> <-Freebies->
(Architect)
Quote - what program do you use to re-assemble frames?
Use a video editor, Flash, or GIF editor. I sitll use ye olde GIF Animator 5 from ULead/Corel, SwishMax Studio, Adobe Flash CS4, and ULead/Corel VideoStudio 11.
I think that some versions of both PhotoShop and Paint Shop Pro came with accessory GIF compositors. Animation Shop came with Paint Shop Pro; ImageReady came with PhotoShop, GIF Animator 5 came with PhotoImpact (and was also available separately). So, you may have a GIF compositor without realizing it. Look in your installed programs for such, and/or see if there's a button/command in PhotoShop or Paint Shop Pro to open the GIF compositor.
There are almost certainly lots of others of which I'm unaware.
OSes: Win7Prox64, Win7Ultx64
i'm wondering what's the estimated time it takes to make 1-5 minutes of a good poser scene... say, two people having a conversation and walking around and picking up stuff. just anything that can make up 1-5 minutes of animation. how long does that usually take to make?
