You can click the small arrow in the upper right hand of the mat room and "apply to all"... but realize that will create the SAME shader on all body materials. You will then have to go back and manually change the image maps back again.
Best to select the fast scatter node in the advanced section and CTRL+C then CTRL+V and manually hook it up... then rinse repeast with the blinn.
doesn't it still have a fastscatter...? even thought it doesn't do the same thing? I know SSS is the new feature in p9... but i thought it still had a node in the menu for fastscat.
The 'SSS' wacro has been there at least since Poser 7. True SSS came out in P9/pp2012..
"Oh - the manual says that? I have never read the manual - this must be why."For P8 I would recommend bagginsbill’s VSS. You need to spend some time learning how to use it, but the results are much better.
Poser Pro 2012 SR3
Windows 7 Professional 64 bit
Intel Core I7 990x 3.46G 6 core
24G RAM
EVGA GTX580 R Video Card
Single HP LP2475 1920x1200 monitor
______________________________
I realize that shift and adding subsurface applies the node to the entire object.
I don't like the default settings though. I want to change the blinn and fastscatter, etc. but when I do the change has to be made to every object part (which is time consuming).
Is there a way to reset the default to a custom and then shift click or a way to make my changes and attach those to the entire object?
Thanks in advance.
EricofSD
