Blend the displacement map with a solid grey (matching the displacement map's background), and adjust the blend.
Take the square root of the displacement map, or use the the arbitrary power function to take the nth root (with n greater than 1). This will compress the range of displacement. It will also shift all values closer to one (white), so you'll afterward need to use a subtract function to shift the map's range back downward.
OSes: Win7Prox64, Win7Ultx64
Attached Link: Mask a Displacement Map
[ ![](http://www.renderosity.com/mod/forumpro/media/folder_10/file_476823.jpg)](http://www.renderosity.com/mod/forumpro/media/folder_10/file_476823.jpg)Renderosity forum reply notifications are wonky. If I read a follow-up in a thread, but I don't myself reply, then notifications no longer happen AT ALL on that thread. So if I seem to be ignoring a question, that's why. (Updated September 23, 2019)
Also, if you are using GC remember that the displacement map gamma should be explicitly changed to 1.0. Otherwise, mid-gray does not equal .5 and you will be left with some offset in what is supposed to be the neutral field.
Hmm. I read your post again, Anth. You use the word "reduce", not "eliminate". Do you mean reduce the displacement and only where the control map is not black? That would be different.
The Blender node Blending value here is .9 - which means the displacement is reduced by 90%. You can adjust the amount of reduction by changing that .9 to something else.
Quote - Blend the displacement map with a solid grey (matching the displacement map's background), and adjust the blend.
This works - blending with the neutral value before the subtract .5 will do the same as what I showed - blending with black after the subtract .5.
The equations - starting with one I can derive the other
Blender(map, .5, mask) - .5
= (1-mask) * map + mask * .5 - .5
= map - mask * map + mask * .5 - .5
= map - mask * map - .5 + mask * .5
= (1 - mask) * (map - .5)
= (1 - mask) * (map - .5) + mask * 0
= Blender(map - .5, 0, mask)
However, the difficulty lies in matching the gray. When gamma correction is enabled with gamma = 2.2, the color chips are assumed gamma = 2.2 and you cannot override that as is done with the displacement map gamma. It is easier to deal with blending with black than blending with .5.
I want to reduce the displacement strength of the image_map_4 with the image_map_5 without changing the displacement value from the PoserSurface.
I try many math function without succes, an idea ?
Thx
Génération mobiles Le Forum / Le Site
