Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 1:08 pm)
not sure who made the outer robe it was a robe i asked for here in the forums but it was no longer available but I found it by accident going through my runtimes i had it installed just forgot the folder it was in.
the inner robes i got from google 3d warehouse that I converted into a conforming figure by doing a parts replacement on the kung fu robe i left the kung fu sleeves intact since they were hardly any different and did not show past the shoulder edges concealed by the tabard.
got this ship from scifi meshes I think it was, but then I gave it a new warp drive system to try to reflect what the new enterprise might be like.
the one over at vanishing point i'm not sure I like that one from the images it does not look accurate enough more like a tng next generation style bridge but not really accurate I think.
I could probably build one I have the chairs and the con and navigation stations think the cieling will be the hardest part to build because it looks like it needs to be nurbed to look right.
then here I am also having problems with sketchup translation where parts of the model have reveresed normals and some parts lost all the smoothing while others did not, there has got to be a way to translate these models without all these issues.
so what I did is i teansmapped the original funiture since it sucked and was really low rez and replaced it with the furniture from the olimpus bridge set.
took some doing to make the textures work in poser but I finally got looking good.
I still need to mske s transmap and redo the arm rank bands because those are going to be cut off with the trans map, and they could look better, the inner shirt I still have to remap and give it it's texture then I think I'm done with this uniform.
The original tng uniforms I think were tight fitting until the 3rd season so Ill be able to remap this one for a good 3rd season uniform.
and I totally got rid of those pants I was useing the mike 2 pants seem to fit pretty well and hang like they are weight mapped and look more like the star trek uniform pants should.
the first three seasons I think I can get away with a pair of pants and the cat suit mapped with the tng pin stripe first second season uniform texture.
