Tue, Feb 18, 11:16 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 7:53 am)
Subject: Removing external runtime libraries
questo ( ) posted Sun, 17 June 2012 at 7:28 AM · edited Tue, 28 January 2025 at 1:29 AM
I'm still getting to grips with P2012 after an extended period of time using DAZ Studio. I have a question about runtime folders which I can't seem to find any answer to...
In moving back from DAZ to Poser I've created a new Poser-specific external runtime and retained a separate DAZ-specific (also external) runtime. When I first set Poser up I pointed it at both in case I screwed anything up in the new folder.
Now I want to point Poser only at the new Poser-specific runtime, but I don't want to delete the DAZ folders (just remove their reference from whatever Poser uses to find files), but I can't seem to do this. The closest I can get is to filter the folders in the Libraries window so that it only shows the Poser one, but is there a better way of doing this? What file does Poser use to specify the paths for runtimes? I can't seem to find that either.
Any help or pointers would be much appreciated!
aRtBee ( ) posted Sun, 17 June 2012 at 7:38 AM
in Libraries, below the category buttons, there is: Show Libraries. Select your Runtime to remove here. If it can be removed, then a [ minus Runtime]  button will show up (next to the [Add Runtime] one).
This button is hidden when: Show Libraries = All, or when the selected library is either the native one or the Downloads one which both come at install time.
questo ( ) posted Sun, 17 June 2012 at 7:43 AM
Aha!
Most excellent, thank you aRtBee.
Followed your advice and job done. Useful for future reference.
