Mon, Feb 10, 4:19 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: Non-docking option for wxPython windows?
face_off ( ) posted Mon, 18 June 2012 at 12:19 AM · edited Mon, 10 February 2025 at 4:27 AM
Hi
I haave searched the wxPython doco high and low, and been unable to determine how to create a wx.Panel window in Poser that does NOT dock when moved on the Poser UI (ie. I want it always floating).  Does anyone know how to do this?
Thanks
Creator of PoserPhysics
Creator of OctaneRender for Poser
Blog
Facebook
grichter ( ) posted Mon, 18 June 2012 at 2:20 AM
no...just starting to mess with wxpython myself and studying the examples under scriptsmenu:partners: that came with p9 and PP2012
they are uncompressed py's in there that do not dock (they float) also snarly's scenefixer is the same uncompressed py that floats that you can see the code used to create the window-panel.
Have a look at those scripts it should give you a hint of how it is done
what I am trying to figure out is a window-panel that sets to a given minimum size and if needed to based on a list of figures and props in a scene grows bigger in the vertical dimension (some are short lists and some are longer lists based on the number of items in a scene that I want to automatically stretch the window to accomodate.
Good luck
Gary
Gary
PhilC ( ) posted Mon, 18 June 2012 at 2:38 AM
Here is an example of a non-docking wxPython window taken from my Python for Poser Tutorial/Manual.
"Hello World" wxPython script.
import wx
import wx.py
import wx.aui
try:
    import poser
    scene = poser.Scene()
    man = poser.WxAuiManager()
    root = man.GetManagedWindow()
    print "Running in Poser 8"
    standalone = 0
except:
    standalone = 1
class MyApp(wx.Frame):
    def init(self,parent,title):
        wx.Frame.init(self,parent,title=title,size=(300,200))
        # add panel
        self.p = wx.Panel(self,id=wx.NewId(),size=(300,200))
        # Background colour to match Poser 8
        # Note that is coloUr not color. Yeah Queen's English :)
        self.p.SetBackgroundColour("#4B4B4B")
        # text label
        self.t1 = wx.StaticText(self,-1,"HELLO WORLD",pos=(10,20))
        self.t1.SetForegroundColour("#FFFFFF")
        self.t1.SetBackgroundColour("#4B4B4B")
if name == 'main':
    if standalone == 1:
        app = wx.App(False)
        frame = MyApp(None, "Hello World")
        frame.Show(True)
        app.MainLoop()
    else:
        frame.Show()
face_off ( ) posted Mon, 18 June 2012 at 3:07 AM · edited Mon, 18 June 2012 at 3:07 AM
Thanks Phil
So basically you do a wx.Frame rather than a wx.Panel, and do not use the poser.WxAuiManager().  Appreciate the help.  I'll try that.
Whilst on the subject, have you tried modal frames/dialogs?  I tried a number of ways to do this, but they all failed (can't remember the error/result), so I figured Poser didn't support modal for a specifc reason.
Blog
Facebook
semidieu ( ) posted Tue, 19 June 2012 at 8:32 AM
They do support modal, at least for wxDialog...
Interesting to see that you don't need to use the WxAuiManager... Question is... if you do without it, is it still possible to determine if the frame was already opened, to avoid having the same script running twice ? (going to try this a little later)
