Thu, Jan 30, 6:53 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 30 4:51 pm)
Subject: Is there Breast Injections for V4.2?
gohanf22 ( ) posted Tue, 19 June 2012 at 7:01 AM · edited Thu, 30 January 2025 at 6:46 PM
Ok I have been trying to find morphers or injectors for breasts for Victoria 4.2.  I know people probably have found them and why I am asking cause I can't seem to locate them.  Does anyone know where I can find some to download on renderosity or on a certain site?  I would be very grateful if someone can point me in the right direction.  Thank you.
3doutlaw ( ) posted Tue, 19 June 2012 at 8:00 AM
V4 Morphs++ at Daz?
gohanf22 ( ) posted Tue, 19 June 2012 at 8:05 AM
I actually have that. How do I make it work. I tried to click on Victoria 4.2 and when I clicked on the chest area, I didn't get any morphers or injectors to use.  Did I install it wrong or something?  Plus she has that purple bikini and no actual Nude skin.  I mean the skin they give you is nude but it don't come with the "other" stuff for the breasts.  Yes I mean the nipples.  Not trying to be perverted or anything but if the nude skin don't have nipples. how can it be a girl at all.  Anyway about the morphs, did I somehow install it wrong and thats why it's not coming up or what did I miss?
operaguy ( ) posted Tue, 19 June 2012 at 8:06 AM
no, she had breast reduction surgery. Permanent.
All kidding aside, go to the marketplace here and try some pertinent searches. You will have many choices. And yes, Morphs++ will give you ample (irony) oportunity to make her built like a ......whatever.
gohanf22 ( ) posted Tue, 19 June 2012 at 8:07 AM
I also have the muscle morphs and I cant seem to get them to work either.  I think I may have installed the morphers wrong somehow.  Is there a right way to install them?
operaguy ( ) posted Tue, 19 June 2012 at 8:07 AM
Lol.
gohanf22 ( ) posted Tue, 19 June 2012 at 8:09 AM
I did didn't I. Sorry if I ask a ton of questions but I'm still sort of new at installing stuff on Poser.
3doutlaw ( ) posted Tue, 19 June 2012 at 8:11 AM
Be easier to help by knowing what version of Poser (or Daz Studio) you are using.
gohanf22 ( ) posted Tue, 19 June 2012 at 8:12 AM
I'm using Poser 9 and its on Windows 7 64 bit.
operaguy ( ) posted Tue, 19 June 2012 at 8:20 AM
when you installed V4 it should have given you options to click on skin maps without the "bikini." even if you did not also purchase the "hi-res" maps.
You can find those under the "Pose" menu (don't ask why they are on that menu.)
3doutlaw ( ) posted Tue, 19 June 2012 at 8:24 AM
Select V4, select, body...then on the paramters dials area, select Morphs|Shapes...if Morphs++ does not show there, then you are not installed correctly.
If it does show there, there is a sub-menu of Breast or Upper Torso
gohanf22 ( ) posted Tue, 19 June 2012 at 8:38 AM
Yeah there isnt any morphers coming up for torso or breast area.  I must've installed it wrong.  Question is, how do I install it right?
gohanf22 ( ) posted Tue, 19 June 2012 at 8:41 AM
I also think I'm installing the Skin Maps wrong. Is there any installation instructions to install these things in the right areas?  It sort of sux that the stuff don't come with instructions on where these need to be installed at.
3doutlaw ( ) posted Tue, 19 June 2012 at 8:45 AM
Poser 9 I believe creates a default "Runtime" in your Users/My Documents area.  If that is OK with you, go ahead and find it via Windows, to make sure you see it.
Once you confirm the location, re-run those installers and make sure to point to those directory locations to install it.
...or you can find where they installed, by searching for "Runtime" on your PC, and just cut/paste/merge that dat into the Poser9 runtime...so your PC is not cluttered.
gohanf22 ( ) posted Tue, 19 June 2012 at 8:52 AM
Well problem is I am not using the default.  I put my Poser 9 in the D drive.  My C drive is only for Windows only.  I dont use the default Users/My Documents.  Is there a way to fix this problem that is being caused?  I have a feeling it has to do with me using D drive as my Runtime area.
3doutlaw ( ) posted Tue, 19 June 2012 at 8:57 AM
Should be fine, you just need to find where it installed the "Runtime" directory.  Mine is on a 2nd drive in a Truecrypt volume...so it's definitely not standard.  For speed, I recommend "Everything" search...its real quick
hborre ( ) posted Tue, 19 June 2012 at 9:10 AM
Did you update V4 after installing the Morph++ package?  If you didn't, the morph channels have not been created yet to accommendate the new package.  Also, the morph package must be installed where your V4 model is located.
gohanf22 ( ) posted Tue, 19 June 2012 at 9:19 AM
Ok so I have to update it in order for the channels to appear?
DustRider ( ) posted Tue, 19 June 2012 at 9:25 AM
Online Now!
Just a guess here, but since no one mentioned "injecting" the morphs, after loading V4, did you go to poses and add the morphs to V4 (I think they are under DAZ People/V4 - but I don't have access to Poser right now)? The morphs aren't automatically added to V4, you need to add them to her through the poses.
__________________________________________________________
My Rendo Gallery ........ My DAZ3D Gallery ........... My DA Gallery ......
gohanf22 ( ) posted Tue, 19 June 2012 at 9:26 AM
I actually tried that but when I use the dial, it did nothing.
basicwiz ( ) posted Tue, 19 June 2012 at 9:29 AM · edited Tue, 19 June 2012 at 9:30 AM
Quote - I actually tried that but when I use the dial, it did nothing.
OK.. this sounds like an initialization problem. Check your desktop for little batchfile to initialize the package for you.
If the Morph+ packages does not do what you want, sitemail me. I may be able to help.
gohanf22 ( ) posted Tue, 19 June 2012 at 9:35 AM
Where do I find the batchfile?
WandW ( ) posted Tue, 19 June 2012 at 9:39 AM
There should be an icon on your desktop to update V4...
gohanf22 ( ) posted Tue, 19 June 2012 at 9:47 AM
Yeah I found it.  I tried to use it but the dials still aren't working like when I use them, it does nothing to the model.
3doutlaw ( ) posted Tue, 19 June 2012 at 9:55 AM
Quote - ...but the dials still aren't working like when I use them, it does nothing to the model.
So the dials are there now?  Above you mentioned the dials were not there?
gohanf22 ( ) posted Tue, 19 June 2012 at 10:43 AM
Yeah I installed it right finally I think.  Problem is now that they appear when I load the morph up but they do nothing.  Like when I turn a dial it does nothing to the model.
gohanf22 ( ) posted Tue, 19 June 2012 at 10:51 AM
OMG I think its finally working.  When I updated Poser 9, the morphs were loaded properly and the dials are now working.
markschum ( ) posted Tue, 19 June 2012 at 11:11 PM
If you want HUGE breasts try freestuff , there was a set there.
