Fri, Feb 14, 7:17 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
Subject: Depth Cueing ?
mickey2 ( ) posted Tue, 04 September 2001 at 4:10 AM ยท edited Fri, 14 February 2025 at 7:10 PM
Hi Gang, I love the look of a depth Cued render, but is there a way to increase the lighting just a little bit. when I set up my lights and use Depth Cueing it cancels out all my lights. can't I have some of both effects at the same time. HELP
Krel ( ) posted Tue, 04 September 2001 at 6:40 AM
I've been able to achieve similar effects to depth cueing by just using spotlights and adjusting their coverage and placement.....this gives you more control......maybe you should abandon the depth cueing setting...... Krel
JeffH ( ) posted Tue, 04 September 2001 at 6:59 AM
Yes, while using the Depth Cue only the things closest to the camera will be well lit. The rest will fade into shadows.
Nance ( ) posted Tue, 04 September 2001 at 11:51 AM
To decrease the amount of depth cueing on the foreground objects, create an invisible prop and move it progressivly farther from the camera until the foreground depth cueing decreases to the level you like. While you can adjust the maximum depth cueing point in this manner, AFAIK, we've never figured out a way to adjust the starting point.
mickey2 ( ) posted Tue, 04 September 2001 at 5:23 PM
Thanks guys for the info I knew that I was in the right neighborhood. ( LOL)
