Wed, Dec 4, 8:41 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 3:06 am)
Subject: Second Skin Question
Taylor-Made ( ) posted Wed, 20 June 2012 at 5:28 PM · edited Tue, 03 December 2024 at 8:41 PM
Has anyone tried Oskarsson's Second Skin for M4 in Poser Pro 2012?  I got the suit and gloves on fine, but the mask and boots will not apply (although they show up in the material room.)  I also can't get the nails to disappear or M4's ears to flatten.  I'm on a tight deadline and need some help.  The suit looks great and is just what I need, but I need the mask too!
FaeMoon ( ) posted Wed, 20 June 2012 at 6:58 PM
I really don't know what could cause that.  Silly question probably, but have you tried restarting everything?  Sometimes if Poser bugs out on me like that, it's the only thing that will fix it.
moriador ( ) posted Wed, 20 June 2012 at 7:26 PM · edited Wed, 20 June 2012 at 7:29 PM
Hmm... I have the same product.
The boots and mask are figures, so you have to load and conform them before the materials will apply to them.
However, I also cannot get the ears, nails, or bodysuit morphs to work.  The parameter dials appear, but they do not affect anything.
I have tried updating M4 using the DxCreateXPFiles bat file, but this has had no effect.
ETA:  The V4 version of the bodysuit works just fine.
moriador ( ) posted Wed, 20 June 2012 at 7:46 PM · edited Wed, 20 June 2012 at 7:51 PM
Okay, I got it.
The M4 version uses PMD's and they are located outside the pose folder.  You need to move them into the folder with the actual injection files.  Then they work.
I don't know how you installed your version, but if you look at the original zip file:
In Runtime>Libraries>Pose>Oskarsson>Second Skin BodySuit M4
You will see 2 folders called Materials and Morphs
and 3 files called BodySuitM4, Ears_Flat, and Nails Gone
If you locate these items in your runtime, and move the 3 files into the Morphs folder just above, the injection poses will work.
