Fri, Nov 22, 6:04 PM CST
Subject: Blackhearted's Irina 2.0 needs Stephanie Petite... Questions
Bendinggrass ( ) posted Sat, 30 June 2012 at 4:35 PM · edited Fri, 22 November 2024 at 5:56 PM
Hello.
Is there a difference between Stephanie and Stephanie Petite? And does SP exist only in the Gen 3 format, bacause I don't remember ever seeing a SP4?
Thanks.
R
mishamcm ( ) posted Sat, 30 June 2012 at 4:38 PM
The origina Stephanie, which was based on Michael 2, was not petite.  Stephanie 4 has petite morphs, but is just called Stephanie 4.  However, if the product requires Stephanie Petite, then it only works with SP3.
3doutlaw ( ) posted Sat, 30 June 2012 at 5:23 PM
From the README it says: Stephanie 3.0 Petite character base, with the SR1 update
Bendinggrass ( ) posted Sat, 30 June 2012 at 5:39 PM
What is the SR1 update?
I know this version of SP is available, but do you need to get all the body and face morphs as well?
SamTherapy ( ) posted Sat, 30 June 2012 at 5:42 PM
The SR1 update is available from DAZ.  I can't remember what it does, however.  You don't need the morph packs to use Irina 2.0, since Blackhearted built a complete set of custom morphs for the character.
Bendinggrass ( ) posted Sat, 30 June 2012 at 6:00 PM
Are there skin textures available for SP too? Are these needed for Irina?
I guess they would be needed for other SP characters. Are they available in Standard and Hi Rez also?
Thanks.
R
WandW ( ) posted Sat, 30 June 2012 at 6:09 PM
If you get the current SP3 from DAZ, it includes the update...
Bejaymac ( ) posted Sat, 30 June 2012 at 6:10 PM
The SR1 update added the International Beauty morph channels to the CR2, iirc you wont need it as the SR1 CR2 should be part of the SP3 download.
Bendinggrass ( ) posted Sat, 30 June 2012 at 6:10 PM
Thanks.
toastie ( ) posted Sat, 30 June 2012 at 6:12 PM
Irina 2 comes with skin textures, think they were fairly hi-res although I haven't used her in a while.
SamTherapy ( ) posted Sat, 30 June 2012 at 6:15 PM
Any Gen 3 texture will fit Steph Petite.  That includes V3, A3, M3 and possibly several more.  The MAT poses for A3 won't work because, although the mapping is more or less the same across the range, the material zones on Aiko 3 are different.
Textures are supplied with Irina 2.0.  All the info about the product is in the Readme, which you can read without buying the product so you can see in advance what you get and what you need.
Oh, and it's a very nice pack, too.
Bendinggrass ( ) posted Sat, 30 June 2012 at 6:27 PM
Thanks.
Yes, Irina is very nice. I didn't know the textures for V3 would fit SP... even though SP is smaller? I guess then any character for SP would have its own textures also?
Is that right?
Thanks.
R
toastie ( ) posted Sat, 30 June 2012 at 7:17 PM
Quote - Thanks.
Is that right?
Thanks.
R
Yup. Irina is nice. She comes with various other goodies I seem to remember.... bikini and snorkling props and some poses I think?
Other characters for SP3 will usually have their own textures unless it says they're just morphs.
LaurieA ( ) posted Sat, 30 June 2012 at 9:08 PM
Knowing Blackhearted and his morphs, you probably won't need the morph package for SP3 either. His are custom morphs. He would have listed that you need the morphs if he'd used them.
nobodyinparticular ( ) posted Sun, 01 July 2012 at 4:49 AM
Amazing what can be done with even the old figures.
toastie ( ) posted Sun, 01 July 2012 at 12:39 PM
Hadn't actually thought about SP3 in ages. In fact I'd almost forgotten I had Irina2 so I'm now dusting her off for a few renders. A3 will have to take a back seat for a few days!
SP3 can use M3 and H3 textures as well. Might sound slightly weird, but I've got some good fantasy and goth skins for the M3 males that look great on the females.
I was a bit horrified when I got M4 recently (because I wanted to finally try out MutedBanshee's M4 characters) that the V4 and M4 skins don't fit each other properly. Wasn't expecting that! :blink:
