Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
I think PFhoe is the low end cost choice, and you can use it with the free Carrara converter:
http://carraracafe.com/?page_id=22&did=17
Follow me at euQfiz Digital
Hi Antaran, yes the MA files will be converted fine in V2C.
Voodoo is a free software and works fine, but PFhoe is more easy to work with. But I think that both can do the same thing at all.
Hi All,
Does anyone here know of the camera match movement software alternatives to SynthEyes, which would also work with Carrara?
As far as I understand from the articles I've found and read, SynthEyes is the best there is, but it's rather too expensive for my needs at the moment. Is there a cheaper alternative that also works? And if there is, what would be the things to know ahead? Pitfalls, disadvantages, special workarounds?
I don't have any experience in the area, so I would appreciate any help you can give me. Workflow tips? Common beginner mistakes I should watch out for? Good resources and tutorials about the subject?
Thank you!
