Mon, Feb 3, 8:14 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: CPUs when ruuning a script
timarender ( ) posted Fri, 06 July 2012 at 5:17 AM · edited Wed, 29 January 2025 at 7:17 PM
Whilst running a long script, I noticed that high CPU activity only occurs on one CPU. In effect, whilst the python scripts runs, the Poser process only ever reached around 25% of the PC's CPU time.
Is this normal? Or what can I do to get it the script to use all 4 of my CPUs?
bagginsbill ( ) posted Fri, 06 July 2012 at 6:12 AM
It's normal and you can't do anything.
timarender ( ) posted Fri, 06 July 2012 at 6:49 AM
Many thanks for the reply and the link.
