Of course. You can also mix in Bryce materials. Material can also be animated. Check out the two girls running movie. Both girls use Poser textures, bump maps whatever & Bryce materials which slowly turn transparent as they run up a hill. When setting up a scene you first import a Poser figure. Then modify material to your liking. Often Poser textures need tweaking to look good. Then material settings are saved and the animation process in started. Susanna will use whatever materials you saved.
Attached Link: http://www.datamike.com/susu.htm
A new feature has been added to "Susanna: Poser Animations to Bryce 4/5": 3d Motion Blur. Bryce does not have a Motion Blur feature and "Susanna" now augments that. Check out the Motion Blur samples at www.datamike.com/susu.htm and click the Motion Blur link.
