have you checked your firewall settings to make sure each machine is not blocking the QM function, and i think there is something about QM only needs to be hard installed on the second machine, worth a try
OS: Windows7 64-bit Processor Intel(R) Core(TM)
i5-2430M CPU @ 2.40GHz, 2401 Mhz, 2 Core(s), 4 Logical
Processor(s) 6GB Ram
Poser: Poser Pro 2012 SR3.1 ...Poser 8.........Poser5 on a bad
day........
Daz Studio Pro 4.5 64bit
Carrara beta 8.5
Modelling: Silo/Hexagon/Groboto V3
Image Editing: PSP V9/Irfanview
Movie Editing. Cyberlink power director/Windows live movie
maker
"I live in an unfinished , poorly lit box, but we call it home"
My freestuff
link via my artist page
as far as im aware, qm only has to be installed on themachine you intend to render on, if qm is installed on the parent machine as well it doesnt work
day........
Carrara beta 8.5
maker
My freestuff
The Poser manual is pretty clear on how to install Queue Manager.
The gist is:
the master machine should have QM in the same folder as the PoserPro.exe. That has to be there to connect with QMs on other (slave) machines, so it's installed by default: you don't have to do a separate installation run for it.
You install QM only - not Poser itself - on the slave machines.
If all your PCs are networked properly, all the QMs will talk to each other. Use the one on the master to manage how jobs are distributed.
PoserPro 11 - Units: Metres
Adobe CC 2017
Hi everybody!
I have been trying for the past 3 days to get queue manager working on #2 computer.
I have a mac pro tower for my host computer and a mac book pro for my node computer. I am running SR2.1 on both machines and all the version numbers match.
I have them both on a network and can talk to one another all day long. but when I try "send to queue" from host machine it just sits there with "adding new queue entry id"
I have triple checked all my settings in QM, so that is not the problem. I dont know why the two QM's cant talk.
I got it to work once, when I reinstalled the sr2.1 update on my host machine and the sr2.1 Queue manager on my node machine, but when I came back from lunch it would not do it again
Please help
Joe C.
