Fri, Nov 22, 5:25 PM CST
Subject: pose file I installed for hair color has no png picture and dose not work on hai
rowlando ( ) posted Sat, 14 July 2012 at 5:17 AM · edited Fri, 22 November 2024 at 12:27 PM
I installed Madelyn hair the pose file contained, poser hr2 and an rsr file only, I installed in Poser Pro 2012 and no images are in the pose folder when opended.
What can I do to fix this please.
cheers Rowlando
Seek what you can never loose
infinity10 ( ) posted Sat, 14 July 2012 at 5:24 AM · edited Sat, 14 July 2012 at 5:25 AM
Poser Pro 2012 cannot read RSR file.  I use RSRconverter, an external app, to change RSR to PNG, then I can see the thumbnails in Poser.
Eternal Hobbyist
rowlando ( ) posted Sat, 14 July 2012 at 5:39 AM
Hi Thanks got the RSR converter and converted rsr files, now I can see the images in poser but they do not add the color to the hair. not sure why any suggestions
PhilC ( ) posted Sat, 14 July 2012 at 6:42 AM
An HR2 file is a hair file not a pose file. It may be dependent on other files, such as geometry OBJ files, for it to be able to load. HR2 files generally should be in the hair library not the pose library.
Is there anything more that you can tell us about the issue?
rowlando ( ) posted Sat, 14 July 2012 at 7:24 AM
Hi PhilC
The files I am talking about are for the pose library they are pz2 plus rsr files so I converted the rsr files to png image files and I cannot get them to work.
I simply manually installed the pose files from the zip and found rsr files did not create an image file I could see to use,
So now i am stuck with how to get these pose files to work?
thanks Rowlando
hborre ( ) posted Sat, 14 July 2012 at 7:49 AM · edited Sat, 14 July 2012 at 7:51 AM
Online Now!
Are we referring to Mylochka's Madelyn Hair found at Sharecg?  I d'led that file and everything appears to be in order.  There are png files along with the rsr's so there was no need to convert the image files.  And the pz2 contain the right paths to the texture files.  Did you install everything from the zip?
Edit:  There is also Madelyn Hair over at DAZ.  I believe I have this one installed, need to check.
hborre ( ) posted Sat, 14 July 2012 at 7:58 AM
Online Now!
The DAZ hair is spelled as Madelyne.
SamTherapy ( ) posted Sat, 14 July 2012 at 12:35 PM
If you're trying to add a colour to a hr2 hair file via a MAT pose on its own, you can't.  It won't work unless the hair is parented to a figure.  Your options would be to either:
Parent the hair to a figure, or
Add the materials manually, via the Material Room, or
See if there's a MAT pose available in the Material Room and if not, create one of your own.
Props - which includes hr2 hairs - cannot accept a MAT pose unless they're parented.
rowlando ( ) posted Sun, 15 July 2012 at 1:42 AM
Thanks SamTherapy
That answers what  i need, your correct, I was trying to change the hr2 color without being parented to V4, the reason I was doing this is because I thought it was OK.
I have learned something new again.
cheers Rowland
