Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 20 6:12 am)
What version of Poser does this? Because I thought it stopped doing that long ago.
Is the file being saved in the same runtime as the file it references?
I'm using PoserPro 2012 and I have the files in a subfolder in Posers runtime.
And that's where I save the files as I work on them but when I go to get it ready for retail, it has the full subfolder information as a path.
Umm, need to clarify that, they are in an external runtime subfolder, not in the Poser runtime...sigh.
You mentioned saving pose files. Why is there a path in a pose file?
In case it has not become clear yet, I have no idea what you are doing.
It's doing this <<textureMap ":SubFolders:!MyWork:Runtime:textures:BE4:BE4_Helen:BE4Helen_Saphire-nails.jpg">>
Instead of this <<textureMap ":Runtime:textures:BE4:BE4_Helen:BE4Helen_Lips-04.jpg">>
And when I am ready to submit this to a market place it has to be edited so the full path info is starting from the runtime only.
If I move my subfolder to the Poser runtime, will it stop adding that first line of stuff?
Hang on. Please be patient, but you are confusing me badly.
To my knowledge, Poser has no way to save a JPG (having to do with materials) in pose files. Yet you seem to be talking about them. Mat pose files are not written by Poser. They are written by other tools.
What tools are you using? What is your workflow?
Poser does save material files and material collections, but you never said those words. You said pose files.
I have dozens of material files saved by Poser and not once have I found an absolute path in them. None are saved to my main runtime, as I have a rule that I do not ever write my stuff into the main runtime.
So your conclusions above are incorrect. You will not solve this by saving to your main runtime because that has nothing to do with it. I save to external runtimes constantly and never see this.
I even just check this scenario:
I load a material which uses a texture in my furniture runtime, and saved this material in my CGAxis runtime. This is across runtimes, neither of which is the main.
This is what is in the material file:
textureMap ":Runtime:Textures:Dreamland_Models:Bedroom Set One:Wood_1621.jpg"
What is in your file? What is that file - mt5, mc6? You said pose. Poser will not write materials into pose files, so you have to be talking about poser writing mt5 or mc6.
Quote - > Quote - so if I use external runtimes I will just have to edit the exact path out...sigh.
No, you have to make that runtime known to Poser. Add it to your list of runtimes
You cannot save a material or a pose to an unknown runtime. You can save a material that mentions a file that is not IN a loaded runtime.
What you seem to be saying is the image file is not in a runtime at all. Maybe it is in a folder structure that someday will be a runtime, but until it's loaded as a runtime in Poser its not an external runtime and the path is absolute.
But how is this happening at all with POSE FILES?
The texture map needs to be in a path that Poser recognises as part of a library. In order for Poser to know that "!MyWork" is supposed to be a library, you need to add it to Poser as a library.
Hi,
Is there a script somewhere that will stop Poser from always adding the directory folder "C:/blah/blahblah/blablahblah/)location instead of starting with "C:runtime:suchandsuch/"?
Every time I edit my pose files Poser adds the entire directiry listing instead of starting with the runtime folder.
Then I have to use a text editor and edit them all over again, that is a load of work. :(
