Fri, Jan 10, 1:00 AM CST
Subject: Easy way to change the skin colour?
aleks ( ) posted Mon, 16 July 2012 at 12:43 PM · edited Thu, 09 January 2025 at 5:36 PM
Iis there an easier way to change the skin colour or hue, except changing one body part after another? I want to keep the texture but to have it slightly darker.
Thanks!
hborre ( ) posted Mon, 16 July 2012 at 1:06 PM
Use the HSV node in the Material Room.  Connect your texture map to that, and connect the HSV node to Alt_Diffuse.
aleks ( ) posted Mon, 16 July 2012 at 3:12 PM
Thanks, but that must be very close to the exact opposite of "easy", especially because you don't get any feedback until you render AND you have to do it for each and every part of the body AND you have to type in the values every time... Changing the texture map in Photoshop and then editing the cr2 was tedious but way easier than this.
I thought more of something like some pose that you can directly apply. Also maybe some Pythone script that applies the values to the whole character.
aleks ( ) posted Mon, 16 July 2012 at 4:06 PM
where's edit? no edit? O_O
cr2 = pz2 of course... :P
basicwiz ( ) posted Mon, 16 July 2012 at 6:15 PM · edited Mon, 16 July 2012 at 6:15 PM
You don't mention what version of Poser you are using. If it's 9 or 2012, then EZSkin will do this for you on the second control screen. http://www.snarlygribbly.org/3d/forum/
Gremalkyn ( ) posted Mon, 16 July 2012 at 6:38 PM
Dump paint - I do.  It only gets complicated if you tweak the color values, but you can save a custom color.
Believable3D ( ) posted Mon, 16 July 2012 at 8:34 PM
Can you change colour with EZ Skin?
In any case, it can be accomplished with VSS.
______________
estherau ( ) posted Mon, 16 July 2012 at 8:57 PM
I have a python script that does it from shaderworks at rdna by semidieu.  I think it is called cororize or something like that.  It's one click.
MY ONLINE COMIC IS NOW LIVE
estherau ( ) posted Mon, 16 July 2012 at 9:21 PM
Attached Link: http://www.runtimedna.com/Advanced-Shaders.html
I can't find the colorize script for you but I found this one which is free which looks like it might also do it.
estherau ( ) posted Mon, 16 July 2012 at 9:25 PM
Attached Link: http://www.runtimedna.com/Advanced-Material-Manager.html
this isn't the one I was thinking of either, but also lets you change one little thing in a material for all your different materials in the figure or just the bits you select with check boxes.   It's really really useful. I have this one too.
Love esther
aleks ( ) posted Tue, 17 July 2012 at 2:15 AM
Quote - I can't find the colorize script for you but I found this one which is free which looks like it might also do it.
Yihaa, Esther, bull's eye! That's the one i need, thanks a million! :)
estherau ( ) posted Tue, 17 July 2012 at 2:43 AM
happy to help.
