Ok, I've got a bit of a problem that apparently isn't going to be as easy a fix as I'd hoped.
Keep in mind I know nothing about how to use SSS beyond the vague descriptions I've read in the reference manual, and the demo thread about SSS on human figures over at RDNA. Nevertheless, I would really like to learn how to take advantage of it.
I'm working on my first scene with SSS, using the Dublin character for V4, which comes with SSS shaders. Trouble is, her skin looks too transluscent, and I need to know how to dial down the translucency. Below is a shot of her face, and the shader nodes that came with the SkinHead.
The scene is indoors, namely the Dream Home Kitchen by DAZ Studio. The lighting is my own setup, using a 4-point system with a Key, Back, and two Fill lights, and IDL. GC is enabled in render settings with all props and figures set to 1 via the MaterialMods script.
Quote - GC is enabled in render settings with all props and figures set to 1 via the MaterialMods script.
I'm curious because people suggest doing this in the forums, but I am a bit confused. What's the advantage to setting GC to 1 via the script, when rendering with GC turned on? Wouldn't it negate the GC?
I understand the advantage of setting all transparencies, displacement, and bump maps to 1. But not for the color image maps themselves.
Color images should be set for the render settings, which would be Gc=2.2. Moriador is correct, Data images only (transparencies, displacement and bump) should be set to Gc=1.
@ Nyghtfall: Scatter node 2 scaling needs to be increased to a value over 1. Typically, 1.5 or greater will reduce the translucency.
There appears to be conflicting information here.
The gamma of an image is not the same as the gamma correction (GC) factor.
Telling Poser that a displacement or bump map has a gamma = 1 does not turn off or disable gamma correction.
Poser's goal in using gamma is to allow for linear calculations. Monitor and image gamma are usually both 2.2, but not all images are PICTURES. Some images are DATA. The DATA images do not have a gamma = 2.2. They have a gamma = 1.
So it is incorrect to tell Poser to use 2.2 everywhere. Only PICTURES are encoded with gamma = 2.2 and you tell Poser to use 2.2 on those pictures. Not on others.
As for the translucence in SSS, scale adjusts the amount of attenuation in the medium. When scale is high, the medium has high scattering (high attenutation, high density particles) and light does not travel very far. When the scale is low, the medium has low scattering and light will travel very far.
The term "scatter" refers to the phenomenon of a photon experiencing interference, preventing it from following its normal straight-line path. High scattering means that a photon is more likely to bounce out near where it entered, instead of traveling all the way to the other side.
Which Material setting controls the degree of translucency in SSS?
