Fri, Nov 15, 4:22 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 15 9:11 am)
Subject: Poser lights select instead of model when posing model
datadraw1 ( ) posted Wed, 25 July 2012 at 3:14 PM · edited Sun, 18 August 2024 at 12:49 AM
Every time I bring a model into poser,  I need to delete lights 2 and 3. when I  select to pose the model only the lights move.
MistyLaraCarrara ( ) posted Wed, 25 July 2012 at 3:30 PM
hold the shift key when you have the model selected, shift key will hold the selection.
bagginsbill ( ) posted Wed, 25 July 2012 at 3:54 PM
Set your scene how you want and save that as your default scene. It's an option in Preferences.
You should not be having to delete two lights every time you start.
Also, you can save scenes in the library now - last category. So  you can quickly load any of many different initial scenes you'd like.
Also, you can save light setups in the library and always could. Use that.
datadraw1 ( ) posted Wed, 25 July 2012 at 6:05 PM
Thanks to everyone, I'm new to Poser so I have lots to learn. I started out with Poser 6 and now using Poser 2012.
