Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 2:39 pm)
That's strange, I don't have any other Mia clothing just the dress :) It's on this page
http://poserworld.com/Downloads/Victoria.4/10628/Mia.for.Victoria.4.aspx
and the zip's name is Mia-V4.
cfpage, I'll try importing it with the weld option in Poser, maybe that will help.
Two misbehaving vertices, as I can see. Put them back in rank :)
But why the trouble with the obj? Just give her the conforming dress, use conform to. Then clothify a part of the dress, eg the skirt might do. Maybe it's a material group already, easy to pick from the list in the group editor.
visit www.aRtBeeWeb.nl (works) or Missing Manuals (tutorials & reviews) - both need an update though
http://poserworld.com/Downloads/Other.Figures/9398/Mia.set.aspx
I don't have the V4 Mia Dress, sorry.
Anyway... Do you have UVMapper Pro? If so, open the geometry file in there, and do Select > Facets > N-sided, then choose 'More than' and 4 sides. That will tell you if there are any >4-sided polys, which is what I would have looked for had I owned the clothing in question... (deep breath)
For dynamic simulation, triangular mesh is best; UVMP can do that for you too, along with any welding that may be needed.
I'm a bit surprised that the dress isn't set up for dynamic (or at least hybrid) use, since Steve generally makes dresses and skirts that way nowadays. Just seen aRtBee's post, I see we are of the same mind. :)
aRtBee, I was originally going to use the conforming version and just clothify the hip part as I usually do but I've used many corrective morphs for the upper arms and collars that the straps just woudn't behave so I figured "why not make the whole thing dynamic?". At some point I did try your suggestion but the skirt part separated from the rest of the dress.
EnglishBob, thank you, unfortunately I only have the free version but will try saving the .obj through that as I recall that fixes some things.
In any case, I just ended up using the dress as a conforming item and it didn't turn out that bad :)
