The IDL precalc gets bigger based on image size. As a result, your memory consumption can be rather huge if you are doing something in the multi-megapixel range. Some people were running out of memory very often.
To help with that, you can use that to change the IDL precalc as if you were doing a smaller image. For example, if have a 2K by 2K image but you set the precalc scale to .5, the precalc will act like it's a 1K by 1K image, and save you 3/4 of the RAM it normally uses.
The downside is detail/resolution may be lost (not that important for IDL) and artifacts will be bigger.
Everything in CG is some kind of nasty trade-off.
Sorry I can't say - I don't read the Poser manuals. (except to point out that other people should read them, and then I show them the part they should have read)
IN poser pro 2012 sr3 Dimension3d render firefly script, I see a precalulation scale box. What is this for?
