Thu, Jan 9, 3:54 PM CST
Subject: OpenGL-Problems
ARCHITECT ( ) posted Sun, 26 August 2012 at 1:23 PM · edited Thu, 09 January 2025 at 3:37 PM
Hello.
I've been busy for a very long time and now - after installing Poser Pro 2012 - I've found some problems running it on my Win7 PC.
I did a search here in the forum but the answers I've found didn't help me so here is my question:
Why turns the figure I've loaded into Poser (64 BIT, the problem occurs in SP2 and SP3 also) black after applying a texture from the library? I can see only the eyes and finger- and toenails then. If I switch from OpenGL to Sreed I get a ugly preview only.
I've changed the lights and the lightmaps, reloaded the textures - nothing will help.
I've found out that I can disconnect the "diffuse value" node but it has to stay at a value of 1.000 - this will bring back the loaded texture in a "normal" colour. But I don't want to do this manually for all the characters and textures.
It's very strange that the the texture-nodes in the advanced materials editor are completely different when I switch from OpenGL to Sreed.
Is there a solution for this problem?
The graphics drivers are new. I've installed all updates for Win 7; The system is a Intel Core i7 3960X, 32 GB RAM and a GForce GTX 580 Twin Frozr so I guess Poser should run on it without any problems.
Any help?
willyb53 ( ) posted Sun, 26 August 2012 at 1:30 PM
Could you post a screengrab of your preview rendersettings please.
Bill
basicwiz ( ) posted Sun, 26 August 2012 at 1:47 PM
Also, does it do this with all textures, or just one particular texture you are applying?
vilters ( ) posted Sun, 26 August 2012 at 1:58 PM
If your textures are in another runtime?
Did you re-connect those runtimes after installing the SR"s???
Questions;
How did you install the SR"s
  1. Remove, -back up, - or maintain preferences?
  2. Did you reconnect all your runtimes?
  3. Check the texture paths in the cr2's. Are those runtimes connected into the library after the SR installs??
Also, show a screengrab from the Render-preview settings
Is HW shading supported on your video card and enabled?
Try: when all runtimes are loaded OK, and you still have BLACK textures.
Click on Reload textures in the render menu.
What happens?
vilters ( ) posted Sun, 26 August 2012 at 2:06 PM
Follow up question?
What and how do you load?
from a cr2?
from an older pZ3?
Check the paths in both, and check that you did not move your runtimes to another path?
LaurieA ( ) posted Sun, 26 August 2012 at 2:14 PM
I found that, after upgrading to SR3, I loaded SP4's texture onto V4 and what I got was a sickly yellow jelly like skin, black scleras and only eye irises were showing the correct texture. I save the file, thinking that it was a Poser glitch, but the weirdness persisted, even after reopening Poser. I haven't tried her textures since, but I will. I've come across a couple weird things in SR3...heh.
willyb53 ( ) posted Sun, 26 August 2012 at 2:17 PM
Also, to determine for sure if it is a openGL preview problem, do the textures render ok or are they bad in render also
Bill
ARCHITECT ( ) posted Mon, 27 August 2012 at 1:17 AM · edited Mon, 27 August 2012 at 1:17 AM
mmmhhhh....
it makes no difference if I open a CR2 or a PZ3. It does NOT happen if I load a standard character like a simple Vicky 4 into the screen. But when I try to apply a texture from the mat-poses (....for victoria 4.x) the mat-pose will load and then the character becomes black or dark-brown. The eyes are visible after that and also the nails.
The renders are fine even if I can't see what I'm doing in the preview screen. Doesn't matter if I use the standard settings or my own. It's in the preview screen only.
I've attached a screenshot from within the materials-room.
At the moment I'm using the Sreed-preview so I can see the textures.
A.
