Forum Moderators: RedPhantom
What's the clipping distance on the camera or whatever its called (min draw?) and how far away is the camera compared to that?
I forget the setting off hand, but can't you have something display in the pose room (handles) but still be invisible in the render?
Do you only get this with V4? Try putting a primitive where her head is and see what happens.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
After this I will post an image of the preview window from the main camera and then an image of what is rendering.
There seems to be nothing between V4 and the camera. Also it is catching her, it's just even if I have the camera pointed dead on her, it renders only her right arm. So it's like it's moving.
I am: aka Velocity3d
I don't know if I have mentioned this before but I can be really simple sometimes..... I'm glad I asked because it kept me looking for the solution instead of restoring defaults but I did figure it out on my own.
I had the render dimensions set ridiculously high. So when I would see the finished render I would only see a small portion of it. 2560 x1920 - my moniter is not that big lol. Also explains why the renders were taking sooooo long.
smdh
I have been caught out by this in the past. I reloaded an old scene and did some changes and then started a render which I abandoned as it the precalculating indirect light was clealy not running as it should. I did that three times until finally I let it complete the render. Only when I noticed the cursor changed when I hovered over the the completed render and I could pan across the image did I realise I had saved the orginal scene with the render dimensions way up for a special render.
I use Poser 13 on Windows 11 - For Scene set up I use a Geekcom A5 - Ryzen 9 5900HX, with 64 gig ram and 3 TB storage, mini PC with final rendering done on normal sized desktop using an AMD Ryzen Threadipper 1950X CPU, Corsair Hydro H100i CPU cooler, 3XS EVGA GTX 1080i SC with 11g Ram, 4 X 16gig Corsair DDR4 Ram and a Corsair RM 100 PSU . The desktop is in a remote location with rendering done via Queue Manager which gives me a clearer desktop and quieter computer room.
I REALLY do not want to restore default settings.
Somehow I messed something up and I am rendering only the grey background. Even when I thought I had a background picture added and I selected to render the background image, nothing only the grey.
If I load V4, select the main camera and adjust it to where her head is smack in the middle of the screen and select to render the whole screen - I still get ONLY the grey.
It also takes an absurdly long time to render.. nothing.
Any ideas?
