Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
Attached Link: Ray Gun Blast
Well what do ya know, it got approved already ;o)
Poser 10
Octane Render
Wings 3D
With Bobby at the helm, why are you surprised? :rolleyes:
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
Actually, the gather node is not useful today. It did a very clumsy job of what IDL now accomplishes in general. Do not use gather in P9. Just turn on IDL.
Gather was fun, but very rudimentary in terms of developing indirect lighting.
There doesn't need to be any new extensions for "bioluminescence" (quotes not to be snarky, but to because I'm assuming this is a very specific effect and not something more precisely modeled after true bioluminescence). For the edge glow effect , just make an ambient material that takes an Edge Blend. You can make it with a black inner color and a white outer color and feed it into Ambient Value to just work with one ambient color, or you can set up two different colors in the Edge Blend and feed that into Ambient Color.
That's the simple approach. If you want to get more creative with your glow, you can do all kinds of things with other nodes. That's the wonderful thing about a node architecture. You can always build your way to advanced materials.
Quote - Actually, the gather node is not useful today. It did a very clumsy job of what IDL now accomplishes in general. Do not use gather in P9. Just turn on IDL.
well although I have Poser 9 (CP made an offer you could not resist) I am rather stuck with Poser 7 still, so gather is still of use to me.
but thanks for the tips.
Quote - Bills and real life expenses keep me from upgrading to a newer Poser, but hoping to get it as soon as things are caught up.
As for the GI in P7, I have the script already, just kinda forgot I had it :o)
Oh! Sorry, I cross-posted. I meant that in response to Kamion saying he has P9 but is stuck in P7.
If you have the hardware to run it, then waiting for a better time to buy P9 is a good idea. By the time I got P7 it was $20. They're always pretty good about selling old copies cheaply or giving them away.
Quote - ----Oh! Sorry, I cross-posted. I meant that in response to Kamion saying he has P9 but is stuck in P7. ----
P8 and P9 have an interface that probably works better on a newer broad screen then I have, so I just cannot get used to it. P7 I do in my sleep so to say.
you know that old worn in easy fitting pants that doesn't flatter you alt all, but wear so nice? something it's the same with P7.
Nice SS/Info BR! I copied it and will try to use it in PP2012 later this weekend! If I can figure out some SSS I will post it, but I am still learning the insides of that one.
HugZ!
Ariana
Is there water in your future or is
it being shipped away to be resold to you?
Water, the ultimate
weapon...
www.futurefantasydesign.com
Quote - Nice SS/Info BR! I copied it and will try to use it in PP2012 later this weekend! If I can figure out some SSS I will post it, but I am still learning the insides of that one.
HugZ!
Ariana
I had to use the Fast Scatter node, but I'm guessing if you made it with true SSS, it would look way cool.
Poser 10
Octane Render
Wings 3D
I will do my best, but honestly if this works in PP2012 I am really liking it as is!!! One question about the way the light is (*at least to me, but I am blind as a bat) little particles. Ideas on smoothing that a touch? Just asking.
HugZ!
Ariana
Water, the ultimate
weapon...
Quote - I will do my best, but honestly if this works in PP2012 I am really liking it as is!!! One question about the way the light is (*at least to me, but I am blind as a bat) little particles. Ideas on smoothing that a touch? Just asking.
HugZ!
Ariana
Easy... I had to use the Gather node on the ground to catch the light(Poser 7 and below)... If you turn on IDL, you'll get much better results.
Poser 10
Octane Render
Wings 3D
Kamion - I totally understand about P9. Comfort with your tool is really important. Just to let you know, you can make everything that floats in P7 float in P8 and P9 as well. That said, I can comfortably shrink my PP 2012 screen to about 1/4 of my screen, where P7 I really could only work at full screen. I generally find that the new interface has much less dead space for icons and labels that are the same size or smaller. I'm pretty definitely missing something in terms of what you're looking for and not finding in the P9 interface, so I'm not betting floating the panels will make things better for you. I just figured you might not know.
FFD - Just to warn, Fastscatter behaves very strangely and inconsistently when you add lights. It technically shouldn't do anything at all without lights because it's a shading node, and shouldn't affect BionicRooster's material at all. I'm betting that it does affect it, which shows how unpredictably it behaves. That's the reason you don't see Fastscatter skin materials everywhere, why there were all sorts of SSS kluges before P9. It was completely unreliable, with raytraced shadows producing major errors.
kobaltkween posted at 8:28PM Thu, 18 January 2018 - #3981361
Is this still true for Poser 11 now? I'm trying to get the results from this thread and it's getting confusing because of all the missing pictures. Nothing like resurrecting an old thread!!
Shadow_Fyre posted at 10:54PM Thu, 18 January 2018 - #4322506
Yes, it's still true. Ambient Value controls your brightness, Ambient Color your color, and if you want to involve Transparency, go ahead. EdgeBlend nodes give you a blend from facing you (inner) to facing away from you (edge). Without an exact example of the look you're going for, I can't say what elements you need, but those are the most common elements for glowing things.
Shadow_Fyre posted at 11:47PM Thu, 18 January 2018 - #4322506
P8/Pro2010+ with IDL can do much better than the gather node. P11 adds the Superfly render engine, which can do glowy stuff even more easily.
I have some material packs with which you could experiment:
refractive ghost, wireframe hologram, and Cortana for Pauline
You may want to dissect some of the glowy materials in some of the other packs:
OSes: Win7Prox64, Win7Ultx64
That is really cool!
