Mon, Jan 6, 10:53 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: is there a list of changes
shedofjoy ( ) posted Wed, 12 September 2012 at 4:10 AM · edited Mon, 06 January 2025 at 10:39 PM
Is there a list of changes between each version of poserpython? i ask this as i would like to attempt to update some if my older python scripts to work with poser pro2012, so far google has only shown me everything but a list of changes, thankyou all for any help.
Getting old and still making "art" without soiling myself, now that's success.
shedofjoy ( ) posted Wed, 12 September 2012 at 4:12 AM
er,just incase that was vague, by list i mean what in the scripting has altered from the older versions to the lastest.
PhilC ( ) posted Wed, 12 September 2012 at 7:41 AM
Best way is to run poserScriptsdocumentation.py for each version and compare the resulting text files.
shedofjoy ( ) posted Wed, 12 September 2012 at 8:28 AM
thanks philc, will give that a go
markschum ( ) posted Wed, 12 September 2012 at 11:33 AM
There was a section for each python version which listed the changes from previous versions.   Up to Poser 7 I think its python 2.4 and after that python 2.7. Also check deprecated functions.
The main change I found is in tkinter where cols went to columns or maybe the other way around.
