Sat, Feb 8, 12:36 PM CST
Subject: Poser props - texture copyright issues
Jacobus01 ( ) posted Thu, 13 September 2012 at 8:57 AM · edited Fri, 07 February 2025 at 5:09 PM
I've done some modelling in the past months, and am thinking of sharing some of my models as Poser props.
The problem is, they're all textured with seamless tiles found on google images, and many of them will have restrictions for distribution. Like completely illegal to adding them in a download of a prop.
My question being, how do you people posting free props get around this ? Do you make all your textures yourself, and if so is there some freeware that helps in this process ?
Tnx.
TheAnimaGemini ( ) posted Thu, 13 September 2012 at 9:04 AM
We use only own ressources , own photos, photoshop work etc..or textures which we buy with the royality free license .
― Marcus Aurelius,
LaurieA ( ) posted Thu, 13 September 2012 at 10:27 AM · edited Thu, 13 September 2012 at 10:29 AM
http://www.cgtextures.com
http://www.plaintextures.com
http://texturebin.blogspot.com/
http://www.imageafter.com/
http://mayang.com/textures/
http://freetextures.3dtotal.com/
and so on and so forth ;).
Read the licenses. They all have them posted on their sites.
Jacobus01 ( ) posted Thu, 13 September 2012 at 10:57 AM
Thanks for the links will check them out.
I discovered that adding the terms 'creative common license' in the search engine works miracles:)
Those are the ones that can be used, just had to find the correct English words for the license.
luckybears ( ) posted Thu, 13 September 2012 at 6:09 PM
Texturing models is a bit of a problem if we are not called Learnardo Da Vinci and what is expected is photorealism. Using our own photos or using our graphic package is optimum and the most satisfying -  create your own texture and you get that buzz of achievnment.
However, and there is usualyl a 'however', it may not be possible for you to take a photo of your needed texture or to create it in corel or photoshop.
There is an alternative that you might find unsatisfatory:
three images here. the first two are thumbnails from Myang, the third is a fusuon of the two that produces something very different: I would really suggest that you do not use anything larger than a thumbbnail that you do not have a right to use.
luckybears ( ) posted Thu, 13 September 2012 at 6:11 PM
2nd image
3rd image
cspear ( ) posted Fri, 14 September 2012 at 9:35 AM
Also have a look at FilterForge, a great tool for making textures.
PoserPro 11 - Units: Metres
Adobe CC 2017
Jacobus01 ( ) posted Fri, 14 September 2012 at 12:28 PM
Thanks all for the reactions... Processing all received information;)
Ajaxx ( ) posted Fri, 14 September 2012 at 1:17 PM
PixPlant and TextureMaker
