Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 8:53 pm)
If there's a picture showing up in your render, then there must be a picture in the shader.
You're also forcing us to assume that's one material we're looking at. Some models have lettering build into them as a separate zone so you don't have to load a picture to color the letters.
Some have two layers of geometry.
Either way, there could be two materials (two shaders) at work here.
Bill, I'll look into it. Thanks. There is no other picture in the shader material.
This isn't about trademark, etc. etc. again. :rolleyes: Can we please just stick to the topic at hand? Thanks......
There was a whole thread about fan art, etc. I think in a way these can fall under that.....
Poser Pro 2012/3DS Max 2013/Adobe Photoshop Elements 10/Zbrush/
PC: HP Z820 Workstation, 3.30 ghz 8 core Intel Processor, 2gig nvidia Quadro, 16 gig of Ram and 2TB Hard Drive.
As you can see, there are some marks on the base paint. How can I get rid of those? That shows the trailer with out any paint texture.......
Laurie, I know the difference between help/trolls etc. Number of posts for the time they joined etc, not staying on topic, etc, etc.....
Quote - As you can see, there are some marks on the base paint. How can I get rid of those? That shows the trailer with out any paint texture.......
Johnny, hit the advanced tab and see what that looks like. I'm betting you have another image file in those nodes somewhere.
You probably won't understand what one node is doing, but any journey begins with one step ;). Learn how to set up a decent shader and you'll be much happier with the stuff you do. Everything is not just textures, simple specular, reflections and bumps. You can create some really good stuff if you take the time to learn. Tho, seeing as how you jump from one thing to the other I'm not sure you'll learn much in the short term. The material room is its own beast, but worth learning.
I emailed the company to ask permission. Still working on it, gonna see what happens. Told them I'd send the render if they'd like to see it.
It's also a trucking company J-Line that I'm using, not the chemical company.
Thanks Laurie --- I'm prepared to give them what ever they need.....
I'm curious too Mark --- should be interesting to hear their response.....
Johnny...you will have to have a release to use that logo on your truck. I came over from the Coord Forum from a head's up re: this issue...I Moderate Freestuff so I thought I'fd give you a head's up as well
Once
in a while I look around,
I see
a sound
and
try to write it down
Sometimes
they come out very soft
Tinkling light sound
The Sun comes up again
Thanks! I'm waiting for them to write back to me. Just emailed late last night and perfecting the texture, so will let you know as soon as I get a reply.....
Hi everyone,
Hope you can help me out here. I'm having an issue with a texture I'm working on for Powerage's Power Truck --
As you can see, I have my new trailer textures in J-Line's Colors, but for some odd reason, I'm getting a ghost texture showing through of the original one.
This is using templates, and applying the colors in the Material room by selecting the template I used in the diffuse section, and then even applying it to highlight.
I'm at a loss. Hope some of you can help me out out there.
Thanks in advance!
This is intended to be a freebie when it's all finished. Doing the cab as well.....
Picture showing the "ghost textures"
