Tue, Nov 26, 7:39 PM CST
Subject: render options
lindans ( ) posted Fri, 21 September 2012 at 11:39 AM · edited Tue, 26 November 2024 at 4:47 PM
Quick query!! When setting up a render (Poserpro 2012) do you just use the render settings tab, just the scripts/partners (dimension 3d/render firefly) or mix and match both - or are there any other options? :huh:
Thanks Linda
Oh, let the sun beat down upon my face. I am a traveler of both time and space ....Kashmir, Led Zeppelin
hornet3d ( ) posted Fri, 21 September 2012 at 11:59 AM
Shaderworks has an Advanged Render Settings script but it is not free.  I tend to use this when I want to set up an number of rendering passes and compile the final image in Paint Shop Pro.
Miss Nancy ( ) posted Fri, 21 September 2012 at 5:53 PM
use d3d's script, in rare cases when certain ray-trace/IDL settings are desired.
seachnasaigh ( ) posted Sun, 23 September 2012 at 12:33 AM
     I mix & match;  I'll start with the render settings - manual tab, save those settings and exit the render settings - manual tab.  I then run D3D's Render Firefly script.  This way, the Render Firefly script uses what I entered in the render settings tab as a starting point, and I only need to adjust a few items.
samhal ( ) posted Sun, 23 September 2012 at 8:56 AM
Hope no one minds a quick question of my own here...
The render button above the preview screen...does it use the most recent render settings regardless if set by the render tab or D3Ds Render Firefly script? Or is it tied to the poser render tab settings?
Thanks! :)
i7 6800 (6 core/12 thread), 24 GB RAM, 1 gtx 1080 ti (8GB Vram) + 1 Titan X (12GB Vram), PP11, Octane/Poser plugin, and a partridge in a pear tree.
Oh, and a wiener dog!
