I read through the tutorial, and can't see anything in there that would make the eyes flip upwards, or indeed affect the eyes in any way at all. So my guess is that you did something that is not in the tutorial, but it's hard to guess what.
If the pz2 contains eye actors - it should not if you followed the tutorial - then certianly take DarkEdge's advice and delete them.
In theory if there are no eye actors in the pose, one would not expect the eyes to be affected by the application of the pose. Unfortunately reality does not always conform to theory. :sad:
It's hard to know what to suggest. It's probably worth doing a render to see if the eyes still look wrong when rendered (might be an OpenGL problem). If the pz2 sets any materials, it's possible that this is a problem with materials, rather than joint rotations. I don't have a lot of faith that these suggestions will prove fruitful, but they are all I can think of at present, I'm clutching at straws.
you know i found that when i load the obj as a morph, that's when the eyes flip. I was following a tutorial for that part from Rebelmommy, except i didn't make the morph in a 3D program, i made it in Daz, saved it as a figure loaded it into poser and then exported the head as an obj, then loaded it as a morph, could that be the issue?
Attached Link: Morph problem
> Quote - when i load the obj as a morph, that's when the eyes flipAfter your last post, I'm 99.9% sure that the eyes are not moving, and that it is actually the head's eye sockets that are moving. If I'm right, then you need a way to move the eyes into alignment with the new position of the sockets. The thread linked above may help.
I am working on making a character pz2 inj using this tutorial http://www.acrionx.com/3d_modelling_poser_tutorials/how_to_make_INJ_REM_Pose_files_for_Poser_custom_face_morphs.php
But when i load the morph the eyes flip upwards and i can manually pull them down after loading the morph, but i can't seem to figure out how to fix the problem so it doesn't happen i the first place.
Any Ideas what my issue might be?
I am using poser 8.
