Wed, Jan 8, 3:39 AM CST
Photoshop F.A.Q (Last Updated: 2025 Jan 06 5:28 am)
Are you up to the challenge??
Subject: getting of photoshop cs3 ext
goofygrape ( ) posted Mon, 01 October 2012 at 3:47 AM · edited Tue, 07 January 2025 at 2:36 AM
Man I need to uninstall CS3ext
Darn computer just wont let me do it normal way
it's no longer in the reg but it shows up in the programe uninstall area,so you can not re install adobe was no help can't under stand the guy offshore ya know .
his english good accent very bad rude in all .
any help will though of as a god send for me
got to put psv7 on to get cs3 so cs4 will go on blabla ect.
thanks
archdruid ( ) posted Mon, 01 October 2012 at 7:32 AM
Try this... it MIGHT work... Since it still shows up in the uninstall, you will probably be able to do this.
go to his address and download the free version... the one you will see at the top of the "page" install it or run it from a thumb drive.. if CS3EXT shows up.. do an advanced uninstall which includes the registry entries and anything "left over". Lou.
http://www.iobit.com/advanceduninstaller.html
"..... and that was when things got interestiing."
retrocity ( ) posted Tue, 02 October 2012 at 8:36 AM
used  the"iobit" prog before on a "really-hard-to-get-rid-of program!!
thnks for the link!
scott!
goofygrape ( ) posted Tue, 02 October 2012 at 10:40 PM
archdruid;
I forgot about iobit thanks it worked just fine.the problem still is here tho,it wiil not install say's I have to finish the other install first.Only problem is there is no other install going on,and with out cs3, cs4 will never install.
thanks are yours
john
archdruid ( ) posted Tue, 02 October 2012 at 11:25 PM · edited Tue, 02 October 2012 at 11:31 PM
Has that happen to me once.. trying to remember how I fixed it.. it was quite a while ago. Lou.
[EDIT] which one is saying it needs to finish install?.. If I remember correctly, the one I had trouble with.. I ended up telling it to install.. then caught it and told it that it was an uninstall.... the ONE time before that, now that I think of it... I restarted the install of the one giving me trouble, then when it was done, uninstalled using something similar to IOBit.. they gadn't invented it yet, lol.
goofygrape ( ) posted Wed, 03 October 2012 at 1:14 AM
now that there is nothing in the reg that is Adobe cs3ext when you try to install said software it still tell's you it cant and stops,quote you cannot install two adobe software's at the same time and exit's
no different then before
I hope that I am comming across ok .
If I dont fix this then cs6 will not go on,and boy that will be money down the tube.(potthanks for all your time and help
John
archdruid ( ) posted Wed, 03 October 2012 at 5:41 AM
ermm.. two things.. are you running a 64-bit system? that is.. for example, Windows7 64 bit?... Also.. do you have the install discs for CS3 EXT?.. one other thing... are you trying to install an upgrade?.. as I recall.. if you remove the original app, the upgrade will not install. Lou.
goofygrape ( ) posted Wed, 03 October 2012 at 10:38 AM
win7 64,upgrade, it installed fine before it had a problem would only work half the time.Adobe said to reinstall that is when the trouble started
archdruid ( ) posted Wed, 03 October 2012 at 3:59 PM
lol... did you check BOTH sets of program files? the "Program Files (x86)" and "Program files"? Lou.
goofygrape ( ) posted Thu, 04 October 2012 at 11:11 PM
yes and have not started reinstall yet will soon
