Sat, Feb 1, 3:02 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Subject: MORPHS?
kumo ( ) posted Mon, 10 September 2001 at 11:35 AM ยท edited Sat, 01 February 2025 at 2:59 AM
how do I use morphs, I have downloaded the elf ears 4 p4nw, but cant seem to get it to work............ please help KUMO
Dr_Pid ( ) posted Mon, 10 September 2001 at 11:41 AM
select object to morph, Select object from top menu bar, select load morph target. Choose the morph, give it a name and it will be added as the top dial.
Marque ( ) posted Mon, 10 September 2001 at 12:34 PM
Double click on the head, (or whatever body part the morph is for, in this case the head because it's a morph for the ears), it will bring up a dialog box. Losd the morph from wherever you have it stored, I put morphs in their own directory. When you load it it shows the name of the morph, and gives you the option to name it whatever you want. Name it the same as the morph to be safe. Then hit ok and you will see a new dial with that name. Marque
shadowcat ( ) posted Mon, 10 September 2001 at 7:43 PM
Double-click or choose object properties with the body part selected.
