Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 08 10:28 pm)
chorographed group means you animate the garment at say at frame 20 left right up or down and in the chorographed group you select the verts you want in your case the strap. it is more doing what are talking about with the sphear minus the sphear
hope this is not to slopy and clear
Personally, I would use the chorographed group for this like cfpage has noted. If you doing it with a sphere as PhilC suggested, you need to constrain the verts to the sphere, which is difficult without also constraining it to the figure. If you don't constrain, but make sure the sphere is touching the sleeve in the beginning of the sim and you SET the cloth to collide with the sphere (you MUST do this), it should follow the sphere. But chorographed is easier.
Hi Laurie,
Thanks so much for the valuable info.
Yes, the problem I'm having with the sphere is how do I constrain just that material zone to the sphere rather than the body. The sphere is my preference because I can animate the sphere so I can control the drape over time. The choreographed works, but is not as precise as the sphere would be.
I will try to get the sphere to push it with collision like you suggest. I only considered pulling it.
Thanks so much for your help.
cheerio
lululee
I would like to be able to control some movement of the bra straps falling down.
I have an extra material zone on the edge of the strap.
Is there any way I can constrain that material zone to a sphere and move the sphere?
cheerio
lululee
