Thu, Feb 13, 3:34 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Feb 12 7:20 pm)
Carrara Free Stuff here.
Subject: compositing question
brenthomer ( ) posted Mon, 10 September 2001 at 11:06 AM · edited Sun, 09 February 2025 at 6:21 PM
Ok I had this little effect I needed in a commercial today. I wanted to take some text and put a cool glow on it and then composite it over some video. The problem was I could not get carrara to generate an alpha matte with aurora. I looked back over some previous threads and saw that this is a bug. Does anyone have any ideals about some alternates? Can I use volumetric lighting somehow? I want an effect similiar to the one I am posting, but I have to be able to generate an alpha matte somehow to use it.
MarkBremmer ( ) posted Mon, 10 September 2001 at 12:05 PM
Hi Brent, Don't know if this is the tool you need: Render with Mask activated, Aura off. Open in PS>duplicate mask>invert selection>gaussian blur Use original mask to select type>float to new layer>delete background>create new layer>select new mask and fill with sampled color from type>adjust as required. Mark www.MarkBremmer.com
Miss Nancy ( ) posted Mon, 10 September 2001 at 4:14 PM
either that, or he could render the aura/text as tiff against a monocolor background, then in APS click on the bg color and feather it in to match the aura edge
AzChip ( ) posted Wed, 12 September 2001 at 11:56 PM
Or, you could render the aura as a light against black background, then composit it in as a layer using "lighten" transfer mode in AfterEffects (which as I recall is what you use for compositing). In my experience, none of the post processing effects actually render with alpha's. Hope this helps. Dex
