Wed, Feb 12, 1:18 AM CST
Subject: new to sss
greyson5 ( ) posted Tue, 23 October 2012 at 11:19 AM · edited Wed, 12 February 2025 at 1:07 AM
sss test
I'm new to this sss business , trying some purchased items & my own settings ,the skin texture looks good but I keep getting black around the mouth .
What am I doing wrong ?
Sa_raneth ( ) posted Tue, 23 October 2012 at 11:25 AM
would help to know which Poser version you are useing
Winterclaw ( ) posted Tue, 23 October 2012 at 11:36 AM · edited Tue, 23 October 2012 at 11:40 AM
Okay, Bagginsbill has a shader over at that fixes this problem.  It's his Max Scatter trick.
Basically you use 2 scatter nodes, one set under 1, the other is set to 2 and you plug them both in to a max node.
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2841702&page=5#message_3881229
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
LaurieA ( ) posted Tue, 23 October 2012 at 11:59 AM · edited Tue, 23 October 2012 at 12:04 PM
For blue around the lips (and this IS the only fix...):
Go into the material room and set the group number on the SSS shader node to a different group other than the one the skin face is in (it's probably 1). Change the group number on the inner mouth, gums, teeth and tongue. That should all clear up for you then. Of course you can also fix all this with EZSkin2 (free). But I normally do it by hand on a shader that's SSS already because it's so easy :).
What's happening is that because all the zones are in the same group, Poser will try and use the WHOLE lot as one SSS object and all the bits that are close together (like teeth, inner mouth, etc) get scaled the same as the head, which will cause this blue color. If you tell the SSS node to scale them each on their own (inner mouth 2, teeth 3, etc) you won't get the blue ;).
vilters ( ) posted Tue, 23 October 2012 at 12:31 PM
You might want to add the eyes to a different SSS group also.
LaurieA ( ) posted Tue, 23 October 2012 at 12:37 PM
Quote - You might want to add the eyes to a different SSS group also.
The only reason I don't is because real eyes tend to get bluish/purplish around the lower lids where the skin gets thinner ;).
I would change the nostrils too tho come to think since they tend to get blue as well and don't in RL...LOL.
vilters ( ) posted Tue, 23 October 2012 at 1:04 PM
Nostrils? Depends, before or after the drinks???
LOL.
Close fitted and SSS-d clothing can become problematic also.
Eyes, yes, depends on the figure.
greyson5 ( ) posted Tue, 23 October 2012 at 3:49 PM
Thanks this has been very helpful
