Mon, Dec 23, 9:54 AM CST
Subject: EZ Skin 2 Question on Props
danidh ( ) posted Fri, 26 October 2012 at 6:01 AM · edited Mon, 23 December 2024 at 9:40 AM
I recently purchased AntFarm's Lenore @DAZ.  She is really a cute little character.  Had no problem using the editor in EZ Skin 2 on her to add her figure but since her eyes and eyelids are props I couldn't figure out how to apply the settings to them.  Is there a way to do this...and please write slowly and use crayons to explain for even though I have been using Poser for over 10 years I still don't know what rigging something means nor do I understand any of bagginsbill's posts on lighting.  smile  Thanks, Dani  (Windows 7, PoserPro 2012 user with all updates installed...don't think this matters but it seems to be the first question everyone asks.)
monkeycloud ( ) posted Fri, 26 October 2012 at 6:11 AM
With the prop as the selected item in Poser, when you launch EZSkin, you can tick the "use hair prop" option, on front tab.
This will let you edit the materials of the prop in the editor tab, and run EZSkin on the prop...
danidh ( ) posted Fri, 26 October 2012 at 7:02 AM
Okay, thank you, I did do that, however, it doesn't appear to be working.  To make sure I moved the eyeball and eyelid off to the side to see if the 1st render swipe included EZ Skin...but it doesn't.
And just to recap, I added each prop via the Hair window and edited it in the editor window and updated the figure for each prop.
bobbesch ( ) posted Fri, 26 October 2012 at 7:49 AM
> Quote - Okay, thank you, I did do that, however, it doesn't appear to be working.  To make sure I moved the eyeball and eyelid off to the side to see if the 1st render swipe included EZ Skin...but it doesn't. > > And just to recap, I added each prop via the Hair window and edited it in the editor window and updated the figure for each prop.
Been there, done that. But the first times i forgot to actually convert the materials.
danidh ( ) posted Fri, 26 October 2012 at 7:52 AM
No, I did that, too.  LOL  I'm beginning to think that maybe eyes and eyelids aren't a really big thing.  Thanks for trying to help, though.
