Tue, Feb 18, 6:42 PM CST
Forum Moderators: RedPhantom
Subject: exporting collada causes corrupted character - Poser 9
rapidator ( ) posted Sun, 28 October 2012 at 8:24 AM · edited Tue, 18 February 2025 at 6:41 PM
Dear friends,
I have exported a character from Poser as collada dae.
After importing it as collada to Blender it looks like a dented tin can. It looks the same way in any other application so it has to be an Poser issue
What happened and how can I fix it?
How can I export a rigged character as collada?
Thank you all in advance
LaurieA ( ) posted Sun, 28 October 2012 at 8:43 AM
There are, uh, problems with the Poser collada export. To say the very least. LOL.
infinity10 ( ) posted Sun, 28 October 2012 at 10:18 AM
Collada is the worst possible exchange format I have ever come across for data interchange between all the modelling apps I have used to-date: Poser Pro through to Poser Pro 2012, Sketchup, Shade 8 through 10, Daz Studio 3 through 4.5, MeshLab, Hexagon 2.5, Blender and MakeHuman.  So.  It's just not very useful at all !
Takes a deep breath.  OK.  Can you consider using any other format ?
Eternal Hobbyist
rapidator ( ) posted Sun, 28 October 2012 at 12:55 PM
I would consider any other format that supports the transfer of a fully rigged character including the animated poses.
bagoas ( ) posted Sun, 28 October 2012 at 4:15 PM
I had same sometime long ago. Re-starting Poser did the trick then, and the baking of morphs. Haven't seen it in Pro 2012.
Are you sure normals are OK and chest morphs are not double (FBM and local on the body part?)
rapidator ( ) posted Sun, 28 October 2012 at 4:19 PM
Looks all fine for me.
Did an upgrade to SR3 and it fixed it all a bit. She doesn't look so miserable anymore but there are still some deformations I could not understand.
Btw. How do I bake morphs? Not sure if I needed it until now
bagoas ( ) posted Sun, 28 October 2012 at 5:43 PM · edited Sun, 28 October 2012 at 5:45 PM
Bake all morphs is one of the options in the Collada Exporter dialog.
rapidator ( ) posted Mon, 29 October 2012 at 1:03 PM · edited Mon, 29 October 2012 at 1:10 PM
my settings look like this.
Lots of settings are greyed out. Must be a Poser 9 issue. Probably with Poser Pro 2012 it will work, but buying it is not an option for now
bagoas ( ) posted Mon, 29 October 2012 at 1:32 PM
Try exporting in mm units and leave out the normals. Not sure if this works, but Poser units are a bit a strange thing for other apps.
rapidator ( ) posted Mon, 29 October 2012 at 1:46 PM
Better! Thanks bagoas! There are still some crudities like sharp edges in the armpits and the groin but it looks better all in all.
I'll play arround with some other settings and will post the result later.
Thanks a lot for your help - so far ;-)
Teyon ( ) posted Mon, 29 October 2012 at 2:01 PM
Also, don't forget to turn the figure into a single skin before collada export. I think that's one of the newer steps to help with compatibility. It should be under Figure>Skinning Method.
rapidator ( ) posted Mon, 29 October 2012 at 3:47 PM
unfortunately this doesn't work in P9...
Teyon ( ) posted Mon, 29 October 2012 at 6:45 PM
AH, I missed that part of the title. Sorry about that.
