Fri, Nov 22, 5:39 AM CST
Subject: Moving objects problem
orbital ( ) posted Wed, 07 November 2012 at 12:01 PM · edited Wed, 06 November 2024 at 9:45 AM
Sometimes when using bryce, I get this problem that nothing but a reboot will fix. Say I create a new object and go to move it. It will only move from one fixed point to the next. To explain it a little clearer imagine point A is where the object is and you have point B. The object will only jump to point B without you being able to move it anywhere between the 2. You can use the edit tool to move an object between the two smoothly but when building a complex model this becomes very time consuming. Just wondered if any of you had encountered the same problem and if you knew of away to fix it without rebooting.
http://joevinton.blogspot.com/
bobbystahr ( ) posted Wed, 07 November 2012 at 12:07 PM
What Bryce needs is a right click to get locations which could then be pasted into the Transform dialogue IMO, but as I don't build complex stuff in Bryce I've never experienced this problem Joe. Be interesting to follow this to see what turns up though.....
I see a sound
and try to write it down
Tinkling light sound
The Sun comes up again
karl.garnham1 ( ) posted Wed, 07 November 2012 at 12:48 PM
Hi orbital
Try changing the resolution when you move your object change static to 8 and motion on 8 and then either have selected on 32 or 64(remember you can change these settings when you want to compress them). That should make it quicker to move but the moving from a-b maybe a problem as when I move objects they tend to go in whatever way they see fit so if you resize an object when its about to be used you get a good result but resizing when its been moved distorts it I have found. I maybe wrong but I hope this helps a bit. Oh and one thing thats handy group your object and then go to create and save it for other files.
Karl
orbital ( ) posted Wed, 07 November 2012 at 1:24 PM
I wasn't gonna reboot after I posted this question, so just saved the scene and closed Bryce. Anyway after 10 minutes out of curiosity I fired up the scene and the objects were moving smoothly. Even so it may have been quicker to reboot anyhow. Just a wierd gltch, that maybe only I get. Suppose it depends on your set up and what programs you are running. Anyway thanks for the replies.
TheBryster ( ) posted Wed, 07 November 2012 at 1:47 PM
Forum Moderator
I've never come across this one before.
kiwi_gg ( ) posted Thu, 08 November 2012 at 11:43 AM
I don't know your system specs but with mine I find that quirky things like that are caused by not enough ram on the graphics card especially when working with larger scene files.
Cheers
GG
WHO said Kiwi's can't Fly ?????
orbital ( ) posted Thu, 08 November 2012 at 1:05 PM
No this is something else, because I create models in a seperate file, then copy and paste them into the scene so I could be when I have only 3 or so objects it might happen.
skiwillgee ( ) posted Thu, 08 November 2012 at 8:02 PM
Make sure you "caps lock" isn't active on your keyboard.  Try moving something with caps lock on and see if that duplicates the problem.
