Mon, Sep 23, 3:18 AM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 22 10:18 pm)
Subject: Seam lines
JIMMYJOHN ( ) posted Thu, 08 November 2012 at 8:08 PM · edited Mon, 23 September 2024 at 1:23 AM
Hello,
On some renders, seam lines between body part textures appear when the model is relatively small because far away in the distance - the smaller the model, the bigger the seam lines (excuse my english, I hope it makes sense).
I have tried to reload the textures to no avail.
Is there a way to sort this out without having to postwork the image?
Thanks,
JJ
willyb53 ( ) posted Thu, 08 November 2012 at 8:15 PM
what is the texture.  some of the elite textures have this problem
If the texture is not a power of 2 (2048/4096 etc) filtering can cause this.
depending on what version you are using, use none or chrisp and see if it makes a difference.
Also change shading rate to .2
Bill
JIMMYJOHN ( ) posted Thu, 08 November 2012 at 8:30 PM
That happens with different merchant textures, no elite, I don't own any. On M4, the head appears to be split in 2 from ear to ear.
I use PP2010, so no crisp I'm afraid. Only none, fast and quality which I'll try as well as the shading rate set at .2.
I'll tell how it went ASAP.
Thanks for your suggestions.
JIMMYJOHN ( ) posted Thu, 08 November 2012 at 8:40 PM
It did work!
You can see the difference with the filtering set to none.
Cheers!
