Thu, Feb 13, 11:59 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:49 pm)
Subject: Script to highlight only non-zero dials.
ElZagna ( ) posted Fri, 16 November 2012 at 2:30 PM · edited Thu, 13 February 2025 at 11:59 PM
Is there a Python script that will highlight only the parameter dials that are non-zero. Alternatively the script could hide all the zero dials.
I know there are scripts that can hide and show dials but they require you to manually go through them all. I was hoping for something more automated.
OS: Windows 10 64-bit, Poser: 10
lowpoly ( ) posted Fri, 16 November 2012 at 3:41 PM
The non-zero dials already have a dot next to them.
Did you need something bigger?
PhilC ( ) posted Fri, 16 November 2012 at 4:23 PM
What do you mean by highlight?
lowpoly ( ) posted Fri, 16 November 2012 at 4:35 PM
you can go into ":runtime:ui:25000_Parameters.psd" and change color on entry 25020_parm_changed_indicator. (make a backup by copy first)
I changed this one to red for better visibilty
markschum ( ) posted Fri, 16 November 2012 at 4:56 PM
file_488595.txt
a script to hide or show the zeroed dials is fairly simple.
import string
scene = poser.Scene()
fig = scene.CurrentFigure()
actors = fig.Actors()
for actor in actors:
    if actor.IsBodyPart():
        parms = actor.Parameters()
        for parm in parms:
            if parm.IsMorphTarget():
                if parm.Value() == 0:
                    parm.Hidden(1)
change parm.Hidden to 0 to show the dial again.
ElZagna ( ) posted Fri, 16 November 2012 at 6:51 PM
Those dots don't show up on my installation of Poser (P8). I found the file and made the changes as **lowpoly** suggested, but I still can't get and change dot to appear.
ElZagna ( ) posted Fri, 16 November 2012 at 7:10 PM
In fact nothing I do to any of those psd files has any affect on the UI.
lowpoly ( ) posted Fri, 16 November 2012 at 7:15 PM
Apparently it is a feature of the "Pro" versions.  I checked it in PP2010 and PP2012 and works as expected, but not in vanilla P8.
ElZagna ( ) posted Fri, 16 November 2012 at 10:48 PM
I just checked out the product comparisons, and it looks like that is a feature specific to the Pro versions.
primorge ( ) posted Sat, 17 November 2012 at 2:48 AM
Yep, the pros get the dots.
primorge ( ) posted Sat, 17 November 2012 at 3:05 AM · edited Sat, 17 November 2012 at 3:08 AM
Oh BTW, the python script above does not work in Poser 8... not on a Mac, at least.
... yes, I dropped the .txt extension. Tried it both from the Scripts Menu and File: Run Python Script. Nada.
ElZagna ( ) posted Sat, 17 November 2012 at 10:02 AM
Thanks, primorge. I thought I was doing something wrong. The script seems to work fine, it's just that nothing gets hidden.
mikegg ( ) posted Sat, 17 November 2012 at 10:16 AM
Lowpoly, could you be a little more specific on how to do this? I found the entry but wasn't sure what to add to change the color. Whats the exact way to change from gray to red.
Thanks,
Mike
ElZagna ( ) posted Sat, 17 November 2012 at 10:30 AM
Primogre & markschum - Change the last line to parm.SetHidden(1)
lowpoly ( ) posted Sat, 17 November 2012 at 11:29 AM
> Quote - Lowpoly, could you be a little more specific on how to do this? I found the entry but wasn't sure what to add to change the color. Whats the exact way to change from gray to red. > > Thanks, > > Mike
I used GIMP in this example, but you can use any 2D image program that will handle a .psd
I select a brush, make it 10 pixel wide and colored red.
Select the layer that has indicator and put drop of red where grey dot is
primorge ( ) posted Sat, 17 November 2012 at 1:26 PM
Thanks, ELZagna...  certainly a useful script, I'll test your suggestion.
ElZagna ( ) posted Sat, 17 November 2012 at 2:31 PM · edited Sat, 17 November 2012 at 2:31 PM
Also if you want to hide the Body parms then you can add a test for "value parameters":
if parm.IsMorphTarget() or parm.IsValueParameter():
mikegg ( ) posted Sat, 17 November 2012 at 3:05 PM
OK, thanks. Really easier than I thought. I opened it in photoshop (duh) and there it was.
Mike
markschum ( ) posted Sat, 17 November 2012 at 3:06 PM
oops, my bad
