Thu, Nov 7, 8:57 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 07 6:34 pm)
Subject: Resizing objs
ArcPaladin ( ) posted Mon, 10 December 2012 at 12:29 PM · edited Thu, 07 November 2024 at 6:39 PM
Hello,
I am trying to resize an OBJ in poser and then export it as an obj. However, everytime I do so it resizes itself back to its original size. What am I missing?
ockham ( ) posted Mon, 10 December 2012 at 12:40 PM
You may be running into a file-naming problem.  Be sure the resized OBJ has a brand-new name, and then be sure the CR2 that uses it has the brand-new name edited in.
If you save the resized OBJ into a different folder under the same name, Poser will most likely keep finding the original non-resized OBJ.
Another possibility: If you're bringing the resized OBJ back in with the "Percent of Figure Size" box checked, it will always be resized to that percentage.  Be sure to UNCHECK ALL BOXES on the import after resizing.
My python page
My ShareCG freebies
geep ( ) posted Mon, 10 December 2012 at 4:18 PM
If you Export it as a "Morph Target" ...
then Poser will ignore any changes to the objects "Scale" and "Rotation" parameters.
Also, UNcheck "Percent of Figure size ... when you Import.
Then your object should Import the same size as when you Exported it.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
