Sun, Feb 16, 12:31 PM CST
Forum Moderators: Staff
Subject: enabled 1 ???
lesbentley ( ) posted Sun, 02 December 2012 at 10:43 AM · edited Tue, 11 February 2025 at 7:17 AM
In PP2012 I saved a Poser box prop, and whilst inspecting the resulting pp2 file, I noticed a new switch "enabled 1" been added to every channel. I tried saving a figure, and again an "enabled 1" switch had been added to every channel. I have never noticed this switch before and have no idea what it does. I tried changing the value to "enabled 0" in some translate and rotate channels, but can't see any obvious change to how the channels work.
Does anyone have any info on what this switch does?
        translateY ytran
            name ytran
            initValue 0
            hidden 0
            enabled 1
            forceLimits 0
            min -100000
            max 100000
            trackingScale 0.001
            keys
                static  0
                k  0  0
            interpStyleLocked 0
            trackingScaleMult 1.000000
markschum ( ) posted Sun, 02 December 2012 at 5:25 PM · edited Sun, 02 December 2012 at 5:38 PM
is there anything in the user interface that toggles that dial or indicates its state. Perhaps in 25000-parameters.psd ?
lesbentley ( ) posted Sun, 02 December 2012 at 10:05 PM · edited Sun, 02 December 2012 at 10:08 PM
Quote - is there anything in the user interface that toggles that dial or indicates its state.
There might be, but if there is, I don't know what it is. I just used ytran as an example, the switch (I'm assuming it is a boolian switch) gets placed in absolutely every channel in the file (pp2 or cr2).
Quote - Perhaps in 25000-parameters.psd ?
What's the "25000-parameters.psd", and where would I find it?
markschum ( ) posted Sun, 02 December 2012 at 10:45 PM
its the photoshop layers for the gui. The various layers are named for what they do. its in runtime/ui  Thre is also the xml .
kirwyn ( ) posted Wed, 12 December 2012 at 3:51 PM
I've often wondered about this myself.  Les, if you ever find out, I hope you can let us all know.
