Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 4:15 am)
This is usually caused by not having a texture in the diffuse channel.
Some figure materials are setup to use the ALT_DIFFUSE channel and set the diffuse channel to a 0 value. If this is the case - plug in the texture in the diffuse channel and leave the value at 0. Then the preview should look fine
If that is not the case - show a screencap of the materials for the face. Maybe we can see of something else is not set correctly
Quote - > Quote - Some figure materials are setup to use the ALT_DIFFUSE channel and set the diffuse channel to a 0 value.
Why do they do this? Is there a benefit to using ALT_DIFFUSE? Seems like this happens after EZSkin is applied as well...
Diffuse and specular give you just those things. So if I plug another node into a diffuse, it'll be diffusified. The Alt channels are place holders.
If all you want is plain diffuse, then difuse is fine. If you want to add SSS or something like that, it isn't.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
The ALT_DIFFUSE channel does not alter its input, it directly transfers it. The diffuse channel takes light and other matters into account. In the nodesetup which plugs into the AltDiffuse, this is already accomplished in the other nodes (and you don't want to apply the light twice!)
I'm using Poser 7, and have a few faces and/or figures that are BLACK before I render them. This makes it impossible for me to change expressions, etc., before I render. The render comes out fine. When I click on the diffuse component face, in the materials room, for example, I'm told there is none. The highlight component is called BarHead05. I can't find that anywhere. The diffuse color is white; highlight and ambient colors are black. It is next to impossible to match the face shade with that of the body by darkening the diffuse color. Any help is appreciated!
