Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 02 9:25 am)
i need more core power to render idl. more cores!
fractal core power @ 128-bits of improbability!
why does it precalc with red dots? why doesn't it calculate as it renders?
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
is that the indirect light calculation it is doing?, does it to me everytime
OS: Windows7 64-bit Processor Intel(R) Core(TM)
i5-2430M CPU @ 2.40GHz, 2401 Mhz, 2 Core(s), 4 Logical
Processor(s) 6GB Ram
Poser: Poser Pro 2012 SR3.1 ...Poser 8.........Poser5 on a bad
day........
Daz Studio Pro 4.5 64bit
Carrara beta 8.5
Modelling: Silo/Hexagon/Groboto V3
Image Editing: PSP V9/Irfanview
Movie Editing. Cyberlink power director/Windows live movie
maker
"I live in an unfinished , poorly lit box, but we call it home"
My freestuff
link via my artist page
One of the best explanations I've seen of what many render engines refer to as Global Illumination. AFAIK, IDL is pretty much the same concept. Hover your moust pointer over the Point Distribution label to see the interaction between the settings vs. render quality and time. Its for Cinema 4D but I think the concepts apply.
one of the authors of FFRender explained that poser uses GI, which includes all forms of illumination, e.g. direct, indirect et al.. there was confusion about this at the time, some believing that GI was synonymous with IBL/AO, a first-order approx. of GI.
GIVariables were introduced in poser 7, at which time there were only 4, but now there are 7.
I find that skins come out a little lighter if I use SSS on dark skins. I use EZskin all the time though, on all characters that will be rendered in close-up. I don't use it on background characters. Some dark-skinned characters have a blueish shade in the diffuse node and that tends to create an unpleasant greyish tinge. I sometimes find I need to tweak that. "Ashen skin" is considered very unattractive by my dark-skinned colleagues.
Poser 11 Pro, Windows 10
Try lowering IDL quality to 8 for draft renders. No need to wait. D3D settings have more control. Save a low and hi setting to library so you can get what you want...fast or slo mo
I find I can turn SSS off when using most dark skins. SSS really works best on pale redheads in a dark room with direct sunlight streaming in. mho..
or has anyone tried that ez skin on Olivia or Kelvin?
haz render drops?
